Oil pressure sensor - dealer scam?
ThatOneGuy_1234
I don't own a Chevy, but I'm trying to help an elderly neighbor with an '05 Tahoe. She took it to the dealership for an oil change, and while there they told her she had a defective "oil sensor for the engine", and they wanted her to come back in so they could run a $179 diagnostic test to see what the issue is.
She's never had the oil light come on, nor CEL, and I didn't see any codes when I used my cheapie reader.
What sensor does this vehicle have, other than the normal pressure sensor that goes to the gauge or idiot light? If it's just this they're talking about, why would they run a $179 test on a $50 part? I'm smelling a scam... if there's really a problem with the unit, I'm guessing I can swap it out for her myself and save her a lot of dough.
Thanks for any help!
HiHoeSilver
Away!
Chicago
This is a very common problem and definitely does not need the dealer to scan it.
Turn the key on, engine off, and observe the oil pressure gauge. If it pegs to 80 without starting the engine, 99% the sending unit is bad.
The part is about $25, and takes less 1/2 hour to change.
SnowDrifter
Sasquatch Country
$179 diag for what you assume is a $50 part. Could be sensor, wiring, gauge, ground, pin issues. Can't comment without knowing truck's history. And while it's likely the sensor, it's not guaranteed. And if the dealer "shotguns" a sensor at it and the problem isn't fixed, now they're in a bad position should the customer choose not to pay for what would be an ineffective repair. Hence the diag fee to cover their ass from a liability perspective.
wjburken
Eastern Iowa
If she just took the vehicle in for an oil change and didn’t have any other issues or CEL on, what caused them to suggest the need for a diagnostic test? Did they happen to mention to your neighbor why they made the suggestion? Seems kind of strange to me but as @SnowDrifter said, we don’t know enough to call scam or not. Might offer to go back with her and ask yourself.
T
ThatOneGuy_1234
Thanks All!
I tried the test suggested by HiHoeSilver and yes, the gauge goes to 80 with the engine off. I see the point about the dealership not wanting to replace without a full set of tests, but I have to think there's a bit of profiteering here as well.
I'll replace the sensor for her and see if that doesn't do the trick.
Wylie_Tahoe
Thanks All!
Id get a new pigtail connector. If the sensor is leaking internally, the oil tends to wick up the wires under the insulation and the seal also swells.
Thanks All!
Let us know how it works out.
HiHoeSilver
Away!
Chicago
Thanks All!
It will. Make sure to use AC Delco. Aftermarket replacements tend to have trouble with service life.
tom3
Something to think about, lots of jokes but it's true in many cases. You replace that sensor and the alternator, transmission, or anything goes bad the next week, "you musta did something" to cause it. You see that the sensor is probably bad, have her take it back to the dealer. Or not.
gpd4
St. Louis, MO
Do not neglect the little gasket under the oil pressure sensor. And I hope you have little hands - the little bastard sits about 6" in front of the radio. I lost one and actually tied fishing line around the next one so I could retrieve it if I dropped it. Found the one I dropped about a year later when I swapped engines...
Where did it land?
Z71Tahoe2004
Colorado
Failures are common. Replacing isn't what I'd call a walk in the park. The link below will take you to a number of videos on how to do it. I've seen a couple in which a guy does it with some socket extensions, but he makes it look easy (I don't think it is). I replaced mine (preventative maintenance) while I had the intake manifold off to upgrade the gaskets. That makes it easy, but that's also a much bigger task than you're probably interested in signing up for. If you want to go that route, there's a bunch of preventative stuff you can do for her while you've got the manifold removed -- like new gaskets, checking to make sure the knock sensor wiring and wells are still good, replacing the crank shaft sensor (next to the oil pressure sending unit), and giving that space a good cleaning.
https://www.youtube.com/results?search_query=replace+chevy+2004+oil+pressure+sending+unit
Good luck.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Difficult to get at, especially with big hands. If they did the diagnostics they will likely charge no further labor because I would ASSUME they would attach a manual gauge during the process and therefore the sensor/sender is already removed. I would really love to know why they said it needs to be tested. What alerted them that may have a problem? I never accept anyone just telling me something is bad or needs looked at until I know why they said that. If is leaking at the end then the call for a new pigtail is right on the money.
SnowDrifter
Sasquatch Country
Failures are common. Replacing isn't what I'd call a walk in the park. The link below will take you to a number of videos on how to do it. I've seen a couple in which a guy does it with some socket extensions, but he makes it look easy.
For what it's worth: A couple wobble extensions or a u-joint or 2 and a thin wall chrome socket make it a 10 minute job, most of which will be spent fussing with trying to line the electrical plug up.
T
ThatOneGuy_1234
OK, just replaced the sender. Easy, 15 minute fix, with the right socket and a U-joint. However, now I'm getting a '0' pressure reading. So there was clearly a problem with the old sender. But why 0 on the gauge? Faulty new sensor? Or, some other issue?
Faulty sensor, incorrect sensor or it's not plugged in. Although, I think some gauges peg out to 80 when the sensor has an open circuit. Or maybe that's a difference between GMT800 and 900.
T
ThatOneGuy_1234
Never mind, user error. The new sender was not identical to the old one, and the pins didn't quite get lined up when I connected it. Took it out and practiced making the connection (it's impossible to even see what you're doing, once it's installed) and then reinstalled and connected. Works great now.
Thanks for everyone's help, neighbor is happy and on her way.
OR VietVet
Willamette Valley
Did you clean out the connector that you reused to plug in to the new sender. At least blow it out?
Even though it is working now, if you did not clean that connector out I would blow it out and blow out at the connection point of the sender.
mfinta
