viven44
Just a small thing to pay attention to while changing oil and/or checking oil level. Viscous lukewarm oil tends to cling onto surfaces and not drain well.
- A fully hot engine will drain about a 1/4th of a quart more than an engine that hasn’t been warmed up fully
- The corollary to this that a cold engine that was turned off when fully hot will also drain almost the same amount as a fully hot engine, as most of it is in the pan already (although won’t drain as fast from the pan as hot oil)
If the oil change was performed after a 5 min drive, you’ll need about 1/4th of a quart less as it didn’t drain fully
