Not so sure anymore- Need guidance
Garandman
Boston, MA and Sunapee NH
Nah. Leather-covered captain's seats, woodgrain, numerous creature comfort doodads such as separate front, rear, driver and passenger climate controls, etc. aren't "utilitarian work truck" features to me.
What about a beam rear axle and limited cargo and passenger space for such a huge vehicle, then?
Beam axle vs. IRS is more of a cost-effective measure. IRS would be more comfy, but the beam axle is plenty sufficient with careful suspension design. I think the Tahoe has plenty of overall passenger space, but the rear passenger leg room is lacking. The third row is pretty much for emergency use only. Personally, I'd rather ditch the third row option and have the second row located back a few inches. If the cargo space is REALLY needed, then one should get a Suburban or Yukon XL.
Nashoba
South Central Oklahoma
Iamdub, how do you like the catchcan? Can you tell it has made a difference in engine efficiency? I have thought of doing that for my 2015 Silverado, and maybe on the '08 Tahoe. Some of the youtube stuff looks good but some of the results are not too successful to make the effort for me.
I didn't install it to increase the engine's efficiency. It's there to keep as much of the blow-by oil out of the intake and combustion chambers as possible. Any amount it collects will always be a positive result versus having no catch can at all. There really aren't any cons to adding one. I consistently drained about 2.5 ounces from mine at every 5K-mile OCI. A couple oil changes ago, I stuffed a stainless scrub pad in it to increase it's coalescent efficiency and I'm now almost filling those 3-ounce cups that I drain it with. So, there is room for improvement. Since trapping oil particles out of the flowing air is the key, running two of these in series should show further improvement. I'd like to know if there's a better design that has the efficiency of two of the ones I have before I mount a second one. I'll never be able to recommend NOT running a catch can on one of these engines.
Serg-214
Im in the minority since I see it a lot on here...but I was never a fan of lowering with anything less than 24s on it. I just thought it looked weird 99% of the time with 20s/22s.
Had an 07 Tahoe lowered 2/4 with 24s for the first 4 years then moved up to 26s the next 5 years before trading it in.
Wish I could lower my 18 Denali XL but with 4 kids now....
Nashoba
Well, by increasing efficiency I was referring to better running by not burning the oily bypass stuff. I can see that you think it is good not to burn that stuff so you answered my question about making for better combustion and cleaner running engine thereby making it more efficient and better performing.
I see what you were asking now, and I agree. Carbon build-up is never a good thing. Engines get enough crud from the contaminants in the fuel, but it's no match for what burnt oil leaves behind.
I've been surprised at how filthy the combustion chambers are on these LS engines when torn down. Our Buicks were never this dirty even after we blew them up! The pistons were always spotless. Now you might have convinced me to get those things or a couple of breathers! LOL
Nashoba
Right now all I do is burn real regular without any ethanol in it and run a can and a half of Berryman's B12 Chemtool through the gas every 45 days or so. It always seems to let the Tahoe get about a mile per gallon mileage better the next tank after the treatment.
PG01
Up here to the right
Thats funny, i blew a hole through many a piston on a bunch of 231 v6’s.... and they were always clean inside...it was fun to tear them apart and see what i did, then go to the junkyard and bring home another clean if up, paint it and put it back in, dime a dozen for them motors ... i learned a lot back then..
I'm a fan of B12 Chemtool. I prefer it over the highly-acclaimed Seafoam.
I'm considering giving my combustion chambers a steam bath after I get the long tubes (catless).
I didn't do it, the plugs had been changed and were fine. After checking #1 we closed the hood and went in to have breakfast and now onto Christmas stuff. Actually, they're going to do Christmas stuff and I'm going to bed.
dizhai
