Mean_Green
- Joined
- Mar 23, 2023
- Posts
- 445
- Reaction score
- 566
Not wild about that other site. Not sure what it is, but I get a bad vibe somehow.
Got it pulled apart and I see the clip.
I pulled the two screws and removed the Trip Odometer. I sort of see how it works, but when I rotate the shaft by hand, the same thing happens. It gets stuck at 9.9 and won't roll over. UNLESS, I apply a slight bit of pressure to the back of the number wheels. Then it flips and keeps counting. Not sure what's going on there.
Edit ... on close examination, the black gear wheel closest to the red clip (left of the 3-4 in the picture), the drive gear wheel if you will, has a small crack, enough to make it loose on the drive shaft. A drop of E6000 hopefully will resolve that. If not, hopefully I can find the Trip Odometer as a separate unit somewhere.
