New Coil Installation.. Jack Stand Placement?? Help Needed!!
rogue status hoho
Okay guys, I just got my Eibach Pro-Kit 2" Drop Coils/Springs in the mail this morning and it's time for installation.. I need help on WHERE do i place the jack stands?? Where do i jack it up from? there rear coils that im doing. Please help with all the jack/ jackstand info you can give me.. and also installation tips or instructions! thanks a ton!
Max
Mile High
Denver
Place the stands in front of the lower control arm brackets on the frame. You'll want to drop the sway bar bolts as well as the lower shock bolts, then pull on one side of the axle and the coil should pop out. Install the new ones and torque everything back down :cheers:
ZaZaZazzels
