Mechanic charges for undone work: how would you address the problem?
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
I think the OP should take a look at the dipstick, wipe the fluid off on a white rag or towel, and post the pic.
I had a paper towel which I used to wipe the dipstick. Dark and gritty. Dunno where it is. Can try again but ...
... I'm leaning toward just dropping it quietly. I can pay someone else to do it properly (and of course I will chack). So I lose another $400-$500. I'll recover.
Related: the first shop (the one I suspect of not completing the servicing) told me my brakes needed replacing. The second shop (who reported the dirty trans fluid) said my brakes would last a while longer.
Guess this is part of the price I pay for not learning to pull wrenches myself, and for not having a workshop where I could try.
That's what driveways are for.
LurkingLuke
LurkingLuke
WA
I guess my concern goes back to my original post: what is the most effective way to bring this up to the mechanic? If I caught him charging me for something he didn't do, he will either apologize (and all will be fine) or he will dig in his heels. I'd like to bring about the first option, but I'm not sure I can prove it strongly enough that he will yield.
An analogy: I order a steak cooked medium rare and it comes out medium well. I could send it back, but I would not trust the cook to not spit on my second steak.
Fless
Moderator
People's Republic of Colorado
Ask …
* Who did the service.
* Can we ask him how he did it?
* Is it ok if I answer your questions about my questions after we’re done?
Then pull the trans dipstick and show them your concerns.
^^^^ This. A year has gone by and there's no telling what it looked like after the "service," so I'd either go back and do the above, or let it go. Confronting the mechanic in an accusatory manner is not going to go well; count on burning that bridge. Asking questions like the above is a consumer's right.
Find a shop you can trust, in case the first shop is under suspicion (although I'm not sure it should be), have the service done, and check the fluid afterward. That's the time to bring up questions about the fluid condition, since most of it should be new. But if it's just a pan drop and filter change, remember that quite a bit of old fluid remains in the torque converter and the transmission body.
SpareParts
North Idaho
Wonder what the second mechanic did to make it look like the first mechanic did not do what you wanted so he could charge you.
How do you know the second mechanic is being honest?
Maybe your trans is going bad from a mechanical defect? 6L80's are known to have early failures.
Im not saying the first mechanic did or did not do the service.
You did not do your part by at least taking the dipstick out to see if the fluid was new or not.
A year later without you ever pulling the dip stick a second mechanic is showing you brown fluid and dirt on the dip stick.
I think a year later you need to chalk it up to experience and next time check things out before you accept the vehicle back.
mikez71
You can't prove anything strongly enough because you have zero proof of anything! Not much to make him yield with..
Other possibilities have been mentioned.. I might be concerned the wrong fluid was used while we're speculating?
It sounds like you're the one digging in your heels, on a hunch, one year later.
You might find out from the next mechanic who changes your filter, if the filter looks original...
own up to the fact that you were not diligent enough to check the work when OR before you paid the bill.
A STEAK DOESN'T TAKE A YEAR TO COOK, like this situation a steak on the grill for a year is long gone turned to dust.........
could it have been accidentally overlooked sure, you posted this almost as month ago and still have the squirrel running in circles?
LurkingLuke
LurkingLuke
WA
ALWAYS check fluids after changes/flushes. In my case, I would even crawl under and check diff fluids. But, I do all my own fluids changes.
Yea, no receipt because you are guessing at the total. Save the damn receipts! Possible transmission problems? Do you tow with the truck? How many miles, 1 year later, after the 82k miles service? "Dirt" on the stick? You can "feel" dirt? Or just looks dirty? Color?
Yeah. Sad that it took me this long to realize this. One of the negatives one finds, having grown up in a high-trust society.
you can't trust anyone, family, friends, etc especially when it comes to money
there is a reason why money is called the root of all evil
there are people out there that will kill you for pocket change, if you don't believe that I can take you to a place you would not dare walk alone
mikez71
OR VietVet
Willamette Valley
at my shop, even if just a oil change i always show the customer the dipstick or new fluid if a coolant flush/job and stuff before they pay to make sure there satisfied
I did a lot of the same things, when I was running shops. Take them to the vehicle and open the hood. Show them anything that could be seen, including dipsticks. Show them the old parts and if they wanted them, all good. If not, we still held for 48 hours and then threw away. They knew they had 48 hours and if they did not contact back, they went in the trash.
petethepug
Michael
SoCal
You could also address the issue of them using an inferior fluid and insist on a comp for another fluid change. You could even suggest you're going to have it analyzed and they’ll make the fluid disappear fast.
DoubleDingo
It's been too long. You need to accept that and move on. Fix what needs fixing and learn from this experience.
kikeap
