Leveling kit
Peter Nelson
I have a 2010 Tahoe LTZ with the Z55 suspension. I plan on replacing the shocks soon, am I able to put a leveling kit in with the OEM shocks?
Big Mama
Virginia
Welcome from Virginia. I’m on the lowered side of the street but I believe you can. Folks with solid knowledge will chime in.
Tozan
Overlander
Yavapai Arizona
If you want to lift the front there are a few shocks out there that will give you a better ride and a lift / level at the same time.
PG01
Up here to the right
Yes and there are many options... above the strut, below or new struts all together... how much do you want to spend is what you need to know.
Peter Nelson
Peter Nelson
Well I’m replacing the front struts. They are electric and I don’t want them to light up my dashboard like the 4th of July. I am after a real smooth comfortable ride, but would like the front leveled with the rear.
Tozan
Overlander
Yavapai Arizona
I have Kings on mine and they are great but if you want to spend less Fox has a few lift struts too.. If you are not as worried about a much better ride there are much cheaper alternatives like Bilstiens, Rough country, Ranchos most of them will work better than stock and if most of your driving is on pavement they will do just fine. Be sure to check compatibility with your truck.
Peter Nelson
Peter Nelson
Well I was looking at arnott shocks because I’m not looking to go crazy right now
griffey_mojo
