Leveling kit
Peter Nelson
I have a 2010 Tahoe LTZ with the Z55 suspension. I plan on replacing the shocks soon, am I able to put a leveling kit in with the OEM shocks?
Big Mama
Virginia
Welcome from Virginia. I’m on the lowered side of the street but I believe you can. Folks with solid knowledge will chime in.
PG01
Up here to the right
Yes and there are many options... above the strut, below or new struts all together... how much do you want to spend is what you need to know.
Peter Nelson
Peter Nelson
Well I’m replacing the front struts. They are electric and I don’t want them to light up my dashboard like the 4th of July. I am after a real smooth comfortable ride, but would like the front leveled with the rear.
Tozan
Overlander
Beauregard, Louisiana
I have Kings on mine and they are great but if you want to spend less Fox has a few lift struts too.. If you are not as worried about a much better ride there are much cheaper alternatives like Bilstiens, Rough country, Ranchos most of them will work better than stock and if most of your driving is on pavement they will do just fine. Be sure to check compatibility with your truck.
Peter Nelson
Peter Nelson
Well I was looking at arnott shocks because I’m not looking to go crazy right now
PG01
Oh yeah I forgot, you can put a spacer under an oem type strut with no lights on dash...
Peter Nelson
Peter Nelson
That’s what I’m looking to do. Ride should be factory quality with the arnott setup is what I hear.
jcsswix
Fox 2.0 coilover setup is not super expensive and is a very nice upgrade. Ride quality is excellent. I run the setup with a small spacer in the rear. The coilovers come preset for the maximum 2" lift/level.
IMG_20190913_163218.jpg IMG_20190510_142817.jpg IMG_20190430_131854.jpg IMG_20190913_163328.jpg
Tozan
Overlander
jcsswix
Are those heavy duty rock sliders you have on that? If so who made them?
These are not extremely heavy duty rock sliders. They do however have a tube that drops down a little below the chassis, and one that extends out wider than the body which offer protection against damage to both the bottom and side of the vehicle. They are not super heavy duty but they are very sturdy and i'd rather damage these than the actual truck itself. These bolt in the stock positions of the factory steps and come with hardware to mount them. They feel very secure and well made. I did a ton of research and could not find out of the box true rock sliders made for these Tahoe's. There are universal rock sliders and brackets I found to fab to bolt on or weld onto the chassis rails. I had removed the stock z71 side steps because I think they're worthless (offer zero protection) and ugly. I would just leave them off and weld low profile custom sliders on except I have three very young children that can't get in and out of the truck without the side steps. I decided to look for better looking ones that suit my taste and actually offered some protection and these were my favorite. They are the Tyger Star Armor side steps:
https://www.amazon.com/gp/product/B076J38KLJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Some closeup pictures:
IMG_20200420_143917.jpg IMG_20200420_144106.jpg IMG_20200420_144119.jpg IMG_20200420_144131.jpg IMG_20200420_145903.jpg
Tozan
Overlander
Thanks James, They do look good but, I see what you mean they are not slider strong but, they would give better protection than nothing. I have the automatic ones on mine now and my wife loves them. So I might have to make something that will be strong enough hitting big rocks and still have an auto step in it.
Tozan
Overlander
MonteJ
