Just Fishing
Can't fix stupid
Did you see any metal flakes in the oil pressure sensor filter?
No more filter, i have the no vlom valley plate now.
But good point, i should pull the sensor and check it.
I also went through my pump last night, it's not terrible.
the housing looks pretty good
but the rotor and slide looks like it might have pumped/grinded up some little bearing bits.
I did some light cleanup of the rough bits, and i think i could use it.
but should i...
it's a $160 pump.
It was pumping just fine, my oil pressure was great and stuff.
the idle oil pressure did start going under 40psi hot...
but i could still pin the oil pressure gauge at wot.
I just searched ebay for that GM piston PN, and came up with this: https://www.ebay.com/itm/Genuine-GM...Top-LS2-LQ4-LQ9-88894241-NEW-OEM/143324493694
The price looks a little too good to be true...
$25 a piston.
looking around they appear to be a good $50 each from places i trust.
Nice!New block just arrived.
If anyone is wondering, the shipping weight was listed at 311 lbs.
Probably won't mess with it until later this week, or this weekend.
It'll lose a little weight when you have it bored to 6.2, 6.3 or whatever.![]()
Now you have me wondering, I wonder what the weight difference between the 6.0 and the 5.3 are...
Meh too lazy to google it, and i sure as hell am not planning on weighing it.![]()
