Is it the rear main???
blazzinbird
Illinois
so we have been loosing oil for a while 1qt every few weeks. There is oil on the bell housing behind the motor. So rear main most likely, but I’ve read if the pcv valve is bad it can cause oil to be pushed out the rear main. Is this correct?
If that's an idea--pcvs are cheap enough to give it a shot, or even try to clean yours out. Take it off and shake it. You should hear a ball moving around. If not, hit it with carb cleaner until you do.
donjetman
Here's the thread I started when I decided to replace the rear main seal.
https://www.tahoeyukonforum.com/threads/rear-main-seal-job-pan-etc-07-yukon-denali-6-2.108334/
Here's the thread I started when I changed the valve cover to the new and improved one.
https://www.tahoeyukonforum.com/threads/valve-cover-change-cleanup.108604/
There's a technical service bulletin TSB# 10-60-01-008M you might be interested in?
https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
Here's a thread I started on valve covers, oil deflector, oil consumption etc.
https://www.tahoeyukonforum.com/thr...tor-oil-consumption-tsb-10-60-10-008m.108493/
JML07denali
Sounds just like my symptoms. Ended up just dropping $1,300 on the rear main seal. Wish I had better news!
Sugai
Have an 2003 tahoe 2 wheel drive, thought was PCV, wrong rear main seal was the Culprit
TejasPitt
