I have a 2011 Chevy tahoe I have taken to dealership already for the gas tank not filling but shutting off.A new canister was installed did not help
pashalaci
Not that I know of.I need to know if I am being lied to.The new canister did not fix problem and all that cost over 400.00 already.The fuel tank will not take fuel keeps shutting down.This is a 2011 Tahoe chevy I took to Jim Brown Chevy
B-train
They need to test the evap solenoid under the hood for being stuck closed. Common cause of this issue. I'm surprised they didn't start there first. Also ask them if all the charcoal was in the canister they replaced. If not, then the lines need to be blown out and could be limiting flow to the evap solenoid on the intake.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum. Like @B-train said, there are some inspections to be done and hopefully some codes were/are present to help point in the right direction. Were there codes or at least a CEL?
Bring it back and ask if they blew out the charcoal from the lines all the way up to the top of the engine. If you do not trust their work, bring it to another dealership. The work is warranted nationwide.
Welcome to the Forum from NH.
Pics of the truck, please.
Moderator
People's Republic of Colorado
It's the other end of the canister that will affect fueling - especially the line to the evap vent valve at the rear of the truck. Having said that, all of the evap lines that are around the tank and canister must be open inside. You could also have a defective filler tube; lots of items to inspect and test.
EDIT: and be sure to turn off the truck when fueling; that will command the evap vent valve to open with the ignition off.
09_4WD_YUKON
Been there, done that!! Not sure what fixed mine, but just replaced the fuel pump twice in the past year and a half. The last time, about 3 weeks ago, they replaced everything, fuel pump, module, canister, purge valve, and solenoid valve, and cleared all of the lines. Has only done it once since, but truck was running while gassing up, killed the engine and it didn't do it again. I have gotten the "Tighten gas cap" msg several times tho. And was told that the fuel pump was full of the charcoal pellets this time as well. I was told by one shop that the tank would need replacing to fix this as well, but not sure how true that is.
Gotta love it when a newbie comes on, asks for help, and then doesn’t come back. Joined Nov 7th, last seen Nov 7th, one post. Hmmm.
There is no "tighten gas cap message" but there is a suggestion/recommendation of that at times.
Yep, looking for the all knowing answer when we are not there and if we do answer correctly, does not come back to say so or at least give an update.
donsaint51
My 2018 Cadillac had this problem. Assumed it was EVAP Canister. Nope. Had to have a new gas tank. $1,600. My 2011 Yukon has not had this problem. YET. Good luck. Irritating that the money spent did not fix the problem.
I can’t think of a single reason to replace the fuel tank for this. It’s only a container. The filler neck maybe, the vapor canister, vent valve, purge valve and blowing out all the plastic lines going into the fuel tank sure but not the tank itself. I would like to know the shops reasoning behind replacing the tank- did they explain that to you?
09_4WD_YUKON
The shop that told me this said there was a "non-servicable check valve" that would clog and not allow the tank to vent properly.
I have never heard of that. The vent valve is replaceable, it’s not in the tank. Strange. I do know there is no such thing on the NBS- I’ve had my tank out.
TallHoe 96 OBS
