How to remove barn yard doors
Symba_The_Lyon
Can anyone tell me how to take the back doors a 1996 tahoe with barn yard doors? Thank you for looking !
qukon 95
YES you have cut the pins i got a set of new pins waiting for me to put on i have a lot of
play in the hinges now i got them from www.totalauto.com #RPL-TAI-GMHK13
qukon 95
no! all welded BUT if you want want to replace the hinges you will need to drill out the spot
welds and the replacement hinges comes with bolts also they have a template on where to
drill the holes.
crows feet
Elberton Georgia
I took a air chisel had to make a bit small enough to fit in hole. drive from bottom up.got my pins from dealer. has extra pin and shims. my holes were wolled out some,after driveing pins and shime in, were fine. doors were on from new and being in mich salt for20 years were a ***** to say the least/////
qukon 95
Did you remove the bumber to get the air chisel straight to drive the pins out?
DallasTahoe
Well I was having the same problem but after getting a good flat round chisel/punch and a two pound sledge I was able to pop the pin out, luckily the door is already damaged hence the need to take mine off, found me a new door for $40 bucks off craigslist! still got to take off the bumper to get the other one out, but no biggie I have to replace the bumper anyway since it got wrecked yet again :mad3:
Symba_The_Lyon
Symba_The_Lyon
Nothing they are still froze up ill end up cuting the pins out just got to find time to do it
ccapehartusarmyINF.(ret)
Gilbert AZ
you take a big set of chains smash out the window run the chains through the window and wrap them around the door and then wrap the other end around the tow hitch of yer buddys tahoe then stand back and tell him to punch it should rip those doors off in a jiffy
Roadboy
Michigan
Good thread. I have one door that has a lot of play in the pin area and the other has succumbed to Michigan salt. Keep us posted and take pics if you get a chance Symba
Roadboy
Michigan
That's really slick! I never would have thought of that. Definitely keep us posted, I may just buy one and try it
qukon 95
it is a little pricey BUT it beats cutting the pins and not putting a little dent in door like i did.
Symba_The_Lyon
Symba_The_Lyon
HOW TO YOU BUY THIS TOOL I HAVE YET TO REMOVE THESE DAMN DOORS LOL I need to remove there doors asap they make my truck look like shit lol
vsaravia
