High pitched noise from stereo
ukrkoz
Auburn WA
Hi all
I have high pitched noise, changing with RPMs, coming from stereo speakers. It is on and off, sometimes louder, sometimes quieter. SUPER annoying. No noise when stereo is turned off. Started about 6 mths ago.
Thank you
intheburbs
SE MI
Interference from the ignition system. First thing I'd do is check/replace your plug wires.
Is your stereo OEM or aftermarket?
Does the noise come from all 4 door speakers at the same time?
tom3
Used to be a problem with alternators doing this but usually with aftermarket stereos. The fix was a filter in the power supply line to the stereo. Any changes in your sound system?
U
ukrkoz
Auburn WA
Stereo is OEM.
BT added about a year ago but it was all fine untill recent.
Alternator is OEM.
Check underhood ground wires. The hood should be grounded to the firewall and there are several others that can contribute to lack of shielding.
Straps, cables, anything that should make a ground. You could experiment a bit with jumper cables, with one end on a good ground and moving the other end to various locations on the truck.
agmanw8n
