Heater core replacement.
chevrol8t
Just replaced my heater core on my `00 Tahoe Yesterday and all I can say is that whomever I pissed off in my past life I am sorry!
Anyway I ran across this video last week showing a mechanic and how he did a heater core swap out that did not look like a disaster area vs other videos I seen. So I bought a replacement heater core (AC evap and blend door actuators (while I was in there) and got it all done in about 12hrs (it's the weekend I'm not racing anyone... :D
Anyway here is the link if it helps anyone. It did for me.
Larryjb
According to your video it appears that you must disconnect the AC evaporator to get to the heater core. Is there a way around this?
chevrol8t
chevrol8t
That is a good question and I'm kicking myself for not seeing if it can be done. Since I was replacing the AC evap as well I did not check to see if it was feasible when I first took it apart.
Larryjb
Your video is one of the best I've seen so far, especially the help to find the hidden bolts behind the dash. I think I"d be tempted to pull the front seats as well, but at the age of 50, I'm getting less flexible. There's nothing like getting a major muscle cramp while under the dash of a car.
GMT800 2005 Tahoe Z71
Navy Supporting Member
The accumulator is disconnected from the evaporator. The evaporator is in the same housing as the heater core. You have to pull the case back to remove the heater core and the evaporator will pull back at the same time. It is also done for room with the lines the heater core pokes thru the firewall for the heater hoses. Lots of hidden bolts and screws and nuts.
chevrol8t
chevrol8t
I hear you. It was no fun that's for sure. Now I understand why repair centers charge so much...
mijohnst
I replaced mine about 6 weeks ago and that video (and much advice form this forum) got me through it. The guy did a great job in the process of showing how and what to do. I even sent him some money for beer through Google. I'm not a superhero like either of you guys because it took me about a week to do mine on and off after work and 2 weekends. I went slow and bagged and labeled everything as well as taking 300 pictures, which turn out to be invaluable. I wish I would have changed out those actuators now that you mention it though.
So congratz on getting it done!
Mike is the resident work horse on the 2000-2006 years. Dedicated to the enth degree for sure.
Larryjb
Did you do the evaporator as well, or were you able to work around it and do the heater core only?
Sounds like a month job for me. I'm always 2x slower than the slowest! ;)
UmmScott
Omaha
Hey chevrol8t..
What was wrong with your heater core? Did it leak or was it plugged?
Pretty sure mine is partially plugged and I'm gonna have to do this before next winter
Sent from my SM-G975U using Tapatalk
chevrol8t
chevrol8t
Hey chevrol8t..
My core was leaking. At first it wasn't to serious. I used a product called "K-Seal" to keep it under control. Actually the K-seal lasted for about 2+years. However not to long ago after replacing my water pump my heater core started leaking again. This time it was bad enough were the steam of anti-freeze was coming through the vents. If yours is not leaking I would by all means attempt a flush first and see what happens.
chevrol8t
chevrol8t
Thanks! Trust me, we are not heroes by any stretch. We just like to wrench and save money when there is none to throw around at a garage. :)
Also two weeks or 12 hrs we get it done!
chevrol8t
chevrol8t
Yes I did! I did the Evap and blend door actuators.
I. Do. Not. EVER. Want to go back in there again!
At least no time soon!!!
Andylbc
