Head block Thread chaser
Summajet
Any members have one I can rent with a deposit. Then return and refund deposit.?
It is for a 03 5.3l v8 motor
ARP 912-0011 11mm x 2.00 Thread Cleaning Tap
Scottydoggs
NJ
what you can do is take one of the old head bolts. then take a angle grinder with a thin disc and cut 2 or even 3 lines in the threads, from bottom to top. then run that bolt in and out of all the blocks threaded holes.
did this on my 3800. worked like a charm. theres vids on yt, search diy thread cleaner.
S
Summajet
That is what I did today. I used an old bolt. I be was just concerned willthat it get it all out the going.
Tomorrow going to run the camera in each hole.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
You can also rent taps at some parts stores if needed. Make sure to not run them in and out without some lube.
S
Summajet
Any idea what the thread size is for the main bearing caps that thread into the block? Trying to find a thread chaser for that
S
Summajet
I was able to get threads cleaned out. I got blocked cleaned. I set the main bearings in the crank underside and top caps on. Will check clearances this week on crank bearings. Then ring gaps and connecting rod bearings. It feels to be making progress. I am not rushing and taking my time to get it back together.
BlacktopBandit76
