Has anyone upgraded sway bars yet on 15+?
Kpwweb
Going to resurrect an old thread.
For those that have upgraded sway bars and are running wider-than-stock tires, did you gain any extra clearance with the aftermarket bars? Do the aftermarket bars still rub?
I have 305s that rub the front factory sway bar; I would rather not rub worse with an aftermarket one!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
I've done well over 300 off them.
Eibach swaybars I have 500 shipped for pair I'm a full dealer
No issues with
22x9 30mm
285 45 22 305 40 22
24x10 30mm offset
295 35 or 305 35 24
26x10 30mm offset
285 30 or 305 30 26
Kpwweb
No issues with
22x9 30mm
285 45 22 305 40 22
24x10 30mm offset
295 35 or 305 35 24
26x10 30mm offset
285 30 or 305 30 26
Thanks!
1sikryd
Do the 2015+ Tahoes use the same swaybars as the 2007-2014, p\n 38106.320? Eibach doesn't list a kit for the 2015's.
mikeyss
Longmont, Colorado.
I don't think there is much of a difference in the front suspension between the NNBS and the 15 and up. The only thing I noticed is on some 15 and up you can have aluminum upper control arms. The aluminum lowers have been around since 2007, but aluminum uppers weren't an option 07-14.
1sikryd
What about the rears? Hotchkis website shows a different p/n for 07-14 vs 15+. Comparing the pictures of the two kits, it looks like the rear swaybars are slightly different.
mikeyss
Longmont, Colorado.
I'm not sure, honestly. The rear bar may be different because they changed the rear axle design and size from 2015 and up.
Tk59194
@NorcalSS
Is there a benifet to running the eibach kit on stock suspension? What is included with the kit?
Laurents10
