Got my 2010 PPV
GCATX
Nope, that was one of the first mods.
If you want the sexy Stainless tips, I bought the kit similar to the SLP kit, bit didn't use it. I'd let it go cheap since you're local
Did taking out the rear resonator make much difference in sound? Does this kit replace the resonator? If so, I will take it, if first guy doesn't.
1BADI5
1BADI5
DMV
Not much louder......makes it sound like you have the 6.2 in the Esky/Denali.
Yes, you cut the resonator out and install this. I opened the box, but never used it
The_Burban
For custom work I'd tell you to contact Wits End Fab in Hanover, MD. Ask for Kenny and let him know I sent you Jeremy aka 1BADI5.
Good dude and they do great work
Just looking for a Setina push bumper preferably. It's be cool to do a steel bumper but that is far away.
I just don't know where all the decommissioned cop cars go and their parts. Saw a guy on eBay selling off an MSP Tahoe.. but no push bumper.
1BADI5
1BADI5
DMV
Well been a productive few hours of bummin around in the garage.
- Wiring harness and switch for airhorn installed.
- New headlight switch for OEM foglights in
- When I took the old head light switch out it was loose......so I had to repair a broken tab with some spare plastic I had on hand for RC trucks.
I'll see what else I can get done before the sun drops
IMG_20200105_152222.jpg IMG_20200105_152215.jpg IMG_20200105_150043.jpg IMG_20200105_132019.jpg IMG_20200105_134146.jpg
1BADI5
1BADI5
DMV
I chose to use the worm clamps to install the horn and compressor so I can remove it quick......and not holes needed to be drilled
1BADI5
1BADI5
DMV
Headlights look great. Are they replacements?
Sent from my SM-G973U using Tapatalk
Yes, one of the first things I did. I hate hazy headlights. I'm ordering Lamin-x film to cover them and the foglights
1BADI5
1BADI5
DMV
I had to adapt........my way ended up working perfect. Sadly, the OEM headlight switch for the foglights was not needed.
IMG_20200110_134158.jpg IMG_20200110_134211.jpg IMG_20200109_191616.jpg IMG_20200110_122106.jpg IMG_20200110_134152.jpg
1BADI5
1BADI5
DMV
Project name "Undercover Sleeper"
What I have done, so far (as of 11 MAR 2020)
- Ported LS7 Throttle body (ported by Me)
- Ported OEM intake manifold w/intake manifold gaskets & injector O-Rings
- AiRaid MIT intake tube / AEM dry filter
- Airbox mod (opened up inner fender and matched the Airbox)
- Hypertech Max 2.0 - tuned for E85/AFM off/trans tune
- Denso IR plugs / Taylor 10.4mm plug wires
- Gates HD Green belt, ac belt, idler pulley, auto tensioner
- Holley powder coated valve covers (Tall) / new braided hoses & inline PCV
- UDR Catch can (black with black braided lines)
- AC Delco Professional 48 series Battery
- Magnaflow muffler 12259
- Rear resonator delete
- Cleaned the MAF
- Royal Purple HMX oil change
- Royal Purple 75w90 Diff service
- Replace both Trans cooler lines (AC Delco)
- StopTech SS lines (front/Rear)
- DOT3 Flush
- AC Delco PPV front rotors
- EBC YellowStuff front pads
- Rear pads
- XTRONs HU with backup camera & forward facing camera & GPS
- OEM Remote Start added - RPO AP8, GM part 19154445
- OEM Auto Dimming rear view mirror
- OEM DIC install
- OEM Tow/Haul shifter
- OEM Steering wheel Stereo controls
- Grant Leather wrapped OEM wheel w/ fresh OEM spoke covers
- Husky mats - front/back/cargo
- New headlight housings w/ LED HI & Lows
- OEM foglights added - OEM switch/lights and wired
- LED light bar, LED tag bulbs, LED brake lights, LED Dome lights (red)
- BellTech 2/3 drop (spindles/springs)
- Spohn adjustable Panhard bar
- AC Delco Professional front sway bar end links
- Goodyear Eagle Ultra Grip GW-3 - 265/60R17) - AMAZING in the rain
- Airhorn install 150+DB
- Dropped the spare tire out, deleted the spare hoist/holder, removed OEM bottle jack and tool kit, removed the spare battery tray, removed about 5 lbs of spare antenna cable from the rear of the truck, removed excess brackets and cabling from under dash
Next up - Ready to install
* OEM PPV shocks/struts & all hardware (ON HAND)
* 60k trans service (fluid/filter) (ON HAND)
* Texas Speed Long tube headers - 1 3/4 (ON HAND)
* Texas Speed 3" catless Y Pipe (ON HAND)
* ATI Harmonic Balancer (ON HAND)
Next year or so
* Gear swap with locker (Yukon Gear & Axle - Ring/pinion and Truetrac limited slip
* Replace the driver side seat cushion and cover (top/bottom)
* Yella Terra Rocker Arms (1.8 ratio)
* Dyno Tune
* AFM delete (w/ Cam swap, LS7 lifters, LS9 head gaskets, C5R timing chain set)
* Procharger (P1X)?
1BADI5
1BADI5
DMV
Well today I finally got something done.
The rear took me about 30 minutes......having a lift makes it easier. The front took me about 2 hours only because I had to cut the lower ball joints (still on 17" wheels) and cut/modify the ABS/wheels speed sensor bracket.
The alignment......LOL. We spent more time racking it up and getting the truck set up then the actual alignment........only the TOE needed to be adjusted.
kbuskill
NE. FL.
View attachment 239220 View attachment 239221
You should post a before pic and an after pic from the side so we can see the difference.
1BADI5
1BADI5
DMV
Yeah I need to take some better pictures too. Those were some quick ones after I rolled it out of the shop
Drewphil
