Fwd stopped working?
Strongheart2012
Was out driving down a back road in 4wd and ended up blowing a rear drive shaft u-joint. Removed the shaft to limp it back home and the front wheels wouldn't move, but I can still move the 4wd shifter. The tranny still spins when I put it in gear. I have no ideas on this one! Looking for some ideas to solve my problem!
95 Chevy Tahoe Ls 4x4 w/ 6in lift and 35s
Strongheart2012
Strongheart2012
Was out driving down a back road in 4wd and ended up blowing a rear drive shaft u-joint. Removed the shaft to limp it back home and the front wheels wouldnt move but I can still move the 4wd shifter. The tranny still spins when I put it in gear. I have no ideas on this one! Looking for some ideas to solve my problem!
Rob Scariano
Omaha
95 Chevy Tahoe Ls 4x4 w/ 6in lift and 35s[/QUOTE
If the front axle lock will not engage then it can not drive the front end either.
Would it engage at all with the rear driveshaft removed. I've never tried that but I haven't heard of any reason why it wouldn't. The transfer case would probably leak without the slip yoke installed tho.
Maybe the transfer case took a dump!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the case has no diffy in it so it could drive the front with rear removed but yest it will leak. see when in 4wd that the front shaft spins as well at the same rate as rear.
BlacktopBandit76
