Front Dash Crack
Definitely not for the **** retentive.....
No sir lol. But I’m the guy who took my entire LT interior out of my Silverado and installed a dash out of a Tahoe so I could retrofit an Esky cluster., then followed with the door panels and had to make my own bezels for it all to work and look factory.
B5F8255A-9DA7-4F1E-826D-B352D3DC7F92.jpeg A347AB6C-63A5-421F-A60A-D52A20D80EC0.jpeg
avalonandl
Troy, MICH & Naples, FL
View attachment 247356 View attachment 247357
You like doing things the hard way......
I don't have time for that.... gotta take a nap....
exp500
Best thing I've found is panel bonder, ( for bodywork)but have to use it from bottom side as its messy. Bonds exellent,allows a little flex so eliminates most new cracks, great to add a few strips to re-inforce original. Use super glue and baking soda from top to fix cracks- a piece of saran wrap will match texture with a little thought. Stop drill ends of cracks 1/8 in bit. Panel bonder fixes everything, hard to justify a $60 gun and $40 tube of glue but you WILL use it more than once.
I used Lord Fusor 142 Plastic Repair epoxy, the best there is for repairing plastics, combined with 1/8” steel rods for reinforcing. I already had the gun. I also used hot staples melted into the back side using a special tool that cost another $100. (I returned it afterwards) It lasted a week before 2 new cracks appeared. My opinion is that once it starts cracking, the plastic is so brittle from either UV rays or heat it’s not worth trying to repair it because it’s just going to continue cracking. I mean, who wants to eliminate “ most new cracks” ? For me, it was a whole lot of work in removing the dash which is not all that easy, bonding/ reinforcing, trying to hide the cracks, reinstalling....hours and hours. Then i could still see the cracks because it’s impossible imo to make them disappear and to top it off it lasted a short time. Have you actually repaired one, do you have pictures, and how long has it lasted? I don’t mean to sound like I’m being negative but my experience suggests it’s not as easy as people make it sound and you’ll probably end up spending a lot of time and money just to end up back where you were. My suggestion is spend the money to buy the new part (which is reinforced in those areas) , add more reinforcement in some form, and install it once and for all.
Brooklyn hoe
Hey guys haven't been on this site for a while but wanted to know where exactly on the dash needs to be reinforced. I have a new dash that I will be installing in the near future.
Brooklyn hoe
Mine cracked in 2 spots but I noticed not everyone dash cracks in the same location
They always crack by the passenger airbag, by the instrument cluster, and if you have the center speaker, right there too. Every time that I’ve seen cracks that’s where they are. Where else have you seen them?
Sparksalot
Bastrop County, Texas
Well my dash finally cracked at the air bag. I decided to try and salvage it. During the process getting it out another crack occurred at the center speaker. I fixed all cracks with the hot staple gun and jb weld plastic bonder. The center clip to hold the front dash has always been missing so I took some 1/16 aluminum and made a new clip. Used the jb weld to secure it. The hot staple helped hold the cracks together. Then roughed up plastic with 80 grit paper. I did find more cracks under the dash once I took it off so I repaired those areas too. I’m very surprised how brittle the plastic is over the years. I will keep this one until it gets worse then replace it. Anyhow here’s some pics.
Has it held up, or cracked elsewhere?
Brooklyn hoe
Wow wow wow 5years later a new house a new born a union strike several jobs and a national lock down, I finally installed my dash. Lol I had to laugh the last time I posted pics of the dash was March 25th of 2016.
Brooklyn hoe
Dash was plasti dip before Installing old dash was cracked in 5 spots.
Dh1280
