ENGINE DECISION TIME!!!!!! opinions please
robhenry2990
Pittsburgh PA
ok i have a 98 4 door hoe with just over 200k on the clock. well i got a ses light for a misfire on cylinder 4. i checked the plugs that i just replaced 1k ago. cyl 4 was fouled and covered in oil. i figure the rings are going. at first i was just gonna gasket everything and redo the spider injection . then i decided ill do a valve job with it. then it was .30 over with a mild cam. then it was stroke it out to a 383. now im thinking of the lq4 swap. i wanna spend around 5k on this project and i found a complete lq4 from pace for $3500. im not sure of what all i need for the swap i saw branndon_b's stuff but it seems he got just about everything he needed when he got the motor. and honestly im open to other ideas to.
bai78
Surviving
Dallas, TX
Can't go wrong with a LQ4 swap! It'll run stronger than any blown sbc, IMHO.
arctic388
can you find a donor truck for the electronics for the lq4.
my vote would be stroke to 383
robhenry2990
robhenry2990
Pittsburgh PA
yea the 383 would be the easiest and if do go that route im gonna by a 350 out of the local junkyard and and do it so i still have my dd.then swap the motor in a weekend. i might be able to find a donor truck for the lq4 in the jy too what all did they come in?
probably be cheaper for the 383
robhenry2990
robhenry2990
Pittsburgh PA
well some how i didnt know about the lq9. i must have been in that cave alot longer than i thought lol. yea im liking the lq9 and i can find them some what cheap used. between 1800-2500 with 55k-120k. the one was 2800 68k with the 4l65. has anyone done this before? what all would i need? and is it possible to change from the electronic tb to to drive by wire?
retorq
Kingman AZ
There is literally a shitload of guys over at performancetrucks.net that have swapped all sort of new gen engines into older stuff. Go do some research there ...
bai78
Surviving
Dallas, TX
Yes, you can swap from electronic to cable driven TB. It's done often that you can find detailed write ups on it.
jdpber
GOLD MEMBER
The America
i would recommend the new GM crate 572.. plenty of power ball loads of torque.. and by gosh it is a nasty motor
620 hp @5,500 and 660 ft/lb @ 4,500
OR how about a Blown 572.. making just over 1,000 HP
jdpber
GOLD MEMBER
The America
dude its just money you can always make more... a camaro with this 572 blown made like 1,200 and ran 244 at Bonniville and set a new record. if that tells you anything about how sick this motor is
when i have my 35 year old mid life crycest i am gonna have a chevelle with on mated to a 6 speed.....
i think this is the best bet for your motor swap.. in all honesty
robhenry2990
robhenry2990
Pittsburgh PA
if i could i would but with 2 kids and a wife im on a budget like 5k i can spend a lil more maybe 6 but that tops it out. i would love to though
jdpber
GOLD MEMBER
The America
ok then.
the LQ9 and 4l65 is gonna eat up every bit of that 6k.. thou an amazing power package.. i think you could build a LQ4 and 4l80 for the same dollar and have more power with same reliability..
simply because there are so many more LQ4 than the LQ9 out on the market and the LQ9 and 4l65 is a highly desired causing the price to be higher...
vsaravia
