Drop kit install- tips, hints and tricks
Labman2012
I have a mcnaughtys 2/3 kit that I am going to install soon and was curious if anyone had some info to make it easier to do? Did you replace ball joints or reuse the existing ones? My hoe only has 60k.
Is there anything I have to do with the rear autoride shocks? I have the shock relocation brackets.
L
Labman2012
Yes
---------- Post added at 12:55 PM ---------- Previous post was at 12:54 PM ----------
Well... Is that the brackets that lower the shock?
NORCAL SS
SUV SUSPENSION GURU
shock extenders are on the bottom but did you can get 10x24 machine screws for autoride links on upper a arms in rear.
L
Labman2012
Do most people delete the air ride? I would like to still have the air adjustment. Is there a difference between doing this and disconnecting the air compressor?
NORCAL SS
SUV SUSPENSION GURU
no dont delete the autoride and you need to do the link with shock extenders in order for it to sit right and function when you tow or load it up.
L
Labman2012
The kit I have is a spindle drop. Is that what your asking?
mfinta
