Does the 6.2L have AFM?
jackD
I’m not clear on this topic. Looking at 2012-2014 Escalades and Yukon Denali with the 6.2L engines.
Do these motors also have the AFM issues?
any way to check if a motor has a lifter issue other than by ear?
Oldewing
Central Ohio
I have a 2014 Yukon Denali 6.2, and yes it has AFM. 140K and counting, no problems as yet. I do think all of the 6.2 in 2014 have it, don't about earlier...
J
jackD
I’ll just take it to my tuner and have him shut it off.
Geotrash
Dave
Richmond, VA
You can tell for sure with any LS engine by looking at the valley pan. If you see the network of passageway castings then the engine has AFM.
I just did a cam swap with AFM and VVT delete to get rid of mine permanently.
Cheers,
Dave
kevinmerlo
I see lots of reference to the 6.2's that came with AFM hardware but it's not active. By hardware, would that include the oil sensor filter that's notorious for getting plugged? I have a new to me '07 Yukon XL Denali with the 6.2 L92. I think I understand it doesn't have AFM but I'm unclear if I'd find that filter under the oil pressure sensor.
I sure appreciate any help on that subject. Thanks.
wjburken
Eastern Iowa
Your 2007 does not have AFM hardware but I’m pretty sure you have a screen under your oil pressure sensor.
kevinmerlo
Thank you for the response. I do see that the valley of the engine does not have that labyrinth of oil galleries so that helps me identify it as a non-AFM setup. That little sensor screen is awfully hard to get to so I was hoping somebody knew this for sure before I went after it.
Thanks again.
Paul dee
Cheers,
Dave
What cam package did you use
petethepug
Michael
SoCal
Tahoe 08 6.2L L92 AFM - No
Tahoe 09 6.2L L9H AFM - No
Yukon 07-08 6.2L L92 AFM -No
Yukon 09 6.2L L9H AFM - No
Yukon 10-14 6.2L L94 AFM - Y
Esky 07-08 6.2L L92 AFM -No
Esky 09 6.2L L9H AFM - No
Esky 10-14 6.2L L94 AFM - Y
Interesting… later discovered the Silverado & Sierra Pickup 6.2L up to ‘13 have no AFM …
07-08 6.2L L92 AFM - No
09-13 6.2L L9H AFM - No
* rare exception is the very early 07 Esky & Yukon 6.2L L92 has AFM hardware, but it’s not active. Pick ups have different criteria, otherwise AFM was installed and active in the above 6.2L starting 2010 MY.
That info is correct for the GM trucks.
The rest of the post is out of quotes for ez reading …
“For some weird reason they detuned the 07 & 08 Denali and the 08 Tahoe to 380 hp. In 09 they let the cat out of the bag. GM matched the 07 & 08 Esky’s 403 hp to all other 6.2L motors.
Unfortunately. they clipped the wings on Tahoe’s 6.2L L9H after 09. In 2010 Tahoe was back to the 5.3L only. GM kept the 6.2L L9H in the Silverado & Sierra trucks til 2013. It was shelved after that and got the AFM 6.2L L94 that the Yukon Denali and Escalade shared starting in 2010.
For some reason some of the above reference links show the 1500 Yukon XL had a L9H 6.2L as a Non-Denali option til 2013. All sales brochures only show the L94 available in the Denali. Esky & Denali did get a 2WD option starting in 09 though. They may have been confused that the Sierra Pick up came in a Denali trim like the YXL Denali.”
Yukon 10-14 6.2L L96 AFM - Y
Esky 10-14 6.2L L96 AFM - Y
Unfortunately. they clipped the wings on Tahoe’s 6.2L L9H after 09. In 2010 Tahoe was back to the 5.3L only. GM kept the 6.2L L9H in the Silverado & Sierra trucks til 2013. It was shelved after that and got the AFM 6.2L L96 that the Yukon Denali and Escalade shared starting in 2010.
For some reason some of the above reference links show the 1500 Yukon XL had a L9H 6.2L as a Non-Denali option til 2013. All sales brochures only show the L96 available in the Denali. Esky & Denali did get a 2WD option starting in 09 though. They may have been confused that the Sierra Pick up came in a Denali trim like the YXL Denali.”
Change L96 to L94 and you're accurate!
petethepug
Michael
SoCal
:hmmm2: Thanks for the clarification on the mix up in the L96/L94 motors. Updated the previous post to reflect it. I had engine swaps on my mind
BlacktopBandit76
