2008 Denali Towing Temps
West 1
West 1
More items to look at before future heavy towing. I am starting to think the 6.2L needs a better cooling system than the 5.3L, more power makes more heat. Does not show up in normal driving but does when you load it up to haul heavy trailers. Sure makes good power though. A noticeable difference over the 5.3L.
West 1
West 1
I towed my boat, maybe 4500 pounds max last week in 98* temps and had to climb some tough grades. Temps climbed again up to 230+ but recovered as soon as I crested the hills. I don't like that and worry that one of these days I will need to push a little harder and exceed what is safe. Today I ordered a 4 core full aluminum radiator and went ahead and added the Oil Cooler and Oil Cooler lines. I will install a new thermostat at the same time. This system was flushed just a year ago with all new hoses so pretty sure the cooling is just not adequate. It has 145,000 miles on it today. I think the current radiator would serve a 5.3L perfectly but is a little short with the 6.2L while towing. Never waivers when not towing. I do not tow that often but when I do I never want to see overheats.
My coolant level in this truck is full, has never changed, never needed to add any since the flush and new hoses so it points to not enough radiator cooling. Adding the oil cooler just adds to peace of mind.
My previous Yukon the 2003 with a 5.3L never overheated with normal towing. Once pulling 7500 pounds ( a 26.5 ft Cobalt Boat with a 502 engine ) from Bakersfield up to Big Bear Lake, zero elevation to 8,000 foot level the temps did climb to 230+ but that truck was wide open in 2nd gear running about 55 mph on some of those hills. When close to 8000 ft one hill had me in 1st gear at 4500 RPM for maybe 5 full minutes and temps only reached 230 or so which scared me. At the top of that hill when I let it idle to cool down the oil pressure was about 20 pounds lighter than normal so I know that engine was as hot as I had ever pushed it. I think this Denali as is could not have made those same pulls without burning up. I hope the larger radiator fixes the heat issues. Time will tell.
kbuskill
NE. FL.
Curious what radiator you bought?
More cores isn't always the best answer.
From what I have researched the wider the tubes the better it cools.
I have a Cold Case all aluminum radiator in my Suburban. It is a dual core but the tubes are like 1.25" wide for each core.
The one warning I will give you is to be prepared to replace the radiator about every 2-3 years due to leaks.
The all aluminum radiators just don't seem to last any longer than that.
Luckily for me the Cold Case has a lifetime warranty so I have had it replaced twice under warranty, I only had to pay for shipping.
If I had it to do over again I would probably just find the biggest core with plastic tanks and forget about it.
West 1
West 1
Thanks for the feedback, it is an Amazon product, not sure of the brand, $310 as I recall. Wish I had your informaiton yesterday. Maybe it is not too late to cancel. All Aluminum sounded like a long term solution up front?
j91z28d1
there's one from DENSO the guys that tow rv on here like. I believe it's a little thicker than stock with plastic end tanks.
Mishimoto makes an all aluminum one with a life time warranty. I believe, I can't think of his user name for the life of me but he runs it and never had it leak? but it's not cheap.
kbuskill
NE. FL.
I now have 2 of the old warrantied out Cold Case Radiators, I hate to scrap them when they just have slow leaks from cracked welds, but I called a Radiator repair shop and spoke with the owner and he said he could potentially fix them and if it didn't work he wouldn't charge for the attempt.
He also said it doesn't matter what brand of all aluminum radiator you use they all eventually do the same thing.
I said the whole reason I went with all aluminum was because I thought it would be a more permanent solution, mentioning how the old brass radiators lasted forever. He said the brass is more forgiving with vibrations.
He said he could build me a brass radiator to the specs of the all aluminum radiators but it would be cost prohibitive.
j91z28d1
I have heard the same thing. but I've get equipment at work with aluminum radiators pushing 30 years old and don't leak. plus every radiator is aluminum these days, just because the end tanks are plastic, doesn't mean the aluminum core doesn't last and they are cheap.
different quality radiators forsure thou, I've read some use epoxy to seal the tubes to the end plates others are Lazer welded. either way, I can only say what I've been around and that all kinds that fail, even the brass ones. and others seem to last forever. I have an aftermarket aluminum radiator made by dewitts in my c6. I got it used off ebay from a wrecked car, minor front end hit, the shipper basically didn't pack it at all, just wrapped some plastic wrap around it. it looked like it fell off a cliff. ports clean broken off from it. ended up refunding me full cost and said toss it. I took it by a radiator shop, they welded on some ports. pressure tested it and said all good. I've run it for years now with no issues. also corvette guys are a different type of people. if they had to replace radiators all the time, that brand would be black listed and never be used agian. since they don't work on stuff themselves, that would be a 1000$ bill every time one leaked, even if it was warranty
West 1
West 1
I have a DeWitts radiator for my 66 Corvette, the car is a full rebuild so it has not been installed yet but yes, they are considered the very best available for a Corvette.
kbuskill
NE. FL.
I get it, just relaying what the radiator repair shop told me. He obviously deals with way more radiators than I do so I just took him at his word.
One of the Cold Case Radiators started leaking from a cracked weld on an end tank.
The other started leaking where the tubes met one of the end tanks.
The tubes/core itself was fine on both.
As for cooling capacity, the first one had a thicker core than the second one.
I believe the first one may have been for a GMT800 because I had to do some minor trimming on the brackets to clear the GMT900 core support.
I sent a message to Cold Case about it and when I got the second one under warranty the changes to the brackets had been made and I didn't have to modify anything, however the core wasn't as thick as the first one.
Still thicker than factory, but not the entire wide of the end tanks like the first one.
All of these had to have a restrictor installed into the small port on the passenger side to match the factory radiator, otherwise the truck would Overcool.
GM, in all their infinite wisdom, programs these trucks so that if the ECM doesn't see a certain temperature within a certain time period it will "Think" that the truck is actually Over heating and turn the fans on High and disable the A/C.
I also mentioned this to Cold Case but they didn't bother to put a restrictor into any of the newer revisions.
Here is a shot of the original VS the first Cold Case Radiator showing the core thickness...
And here is a shot of the first Cold Case VS the second Cold Case...
And here is a couple shots of the restrictor I ended up making from an old TPMS sensor metal valve stem.
I simply cut it off the sensor and removed the valve stem core and twistedthe threads up into the radiator port to secure it.
Kind of hokey I know, but it was aluminum so I didn't have to worry about rust or galvanic corrosion from dissimilar metals and it already had a hole in it that was close to the factory restrictor in the original radiator, so I took it as a win.
I have often wondered how opening up the restrictor on a factory radiator would affect the cooling.
It would be interesting to try, especially for someone who has issues with overheating when they are towing a trailer.
This hose comes off the radiator and plumbs into the engine right behind the thermostat so that explains why it causes it to Over cool. It effectively bypasses the thermostat.
Would be kind of cool to drill out the factory restrictor and then install a ball valve or something into that hose, that way when you needed more cooling, like when towing, you could open the valve up more, and when you were just driving around town you could restrict it down so the ECM didn't go into that default mode I mentioned earlier.
Or it might not affect it that much if the thermostat was already opened up all the way, although I would have to imagine increasing the flow would have to help because even when the thermostat is wide open it still restricts flow to a certain degree.
But my brain works differently from most... lol
West 1
West 1
I looked at the Mishimoto Radiators? Looks like they are almost $800. The specs look good but that is a lot.
Marky Dissod
Looks like you get about 4x the radiator for about 4x the price. Seems close to fair, to me, except that many of us don't need 4x the radiator ...
Where can one get 2.5x the radiator?
I would recommend
1. B&M deep transmission pan
2. External transmission cooler of your choosing
but... do not mount it in front of the radiator, on the denali you can remove the black plastic behind the bottom plasti-chrome grill and allow air flow there.
mine is mounted there under (in front of) the forward splash guard
3. use 6an lines and fittings, the rubber lines & clamps supplied with almost any transmission cooler will eventually leak or seep.
this will drop the overall transmission temps 15-20 degree's. or more if not under a load. just depends on how hard you push it.
the highest temp I have seen since doing this is around 227 pushing it hard at high elevation in 90 deg heat
driving it wide open throttle light to light at lower elevation (in 100deg weather) I will see 205/210/215, so without the modification it would have been 220-230+ easily
that was my entire reason for adding extra cooling, without the added cooling I would hit 220 in a few minutes just driving (my style) i don't drive like granny, ever.
when i do drive somewhat "normal" transmission temps may run 135-165, even that driving is probably on the excessive side for most people, I just have a heavy foot.
if i ever mess with it again I would go with a pusher fan for the transmission cooler I think that would be the ideal solution.
West 1
West 1
Sounds like you made many positive changes to keep temps down. If I read correctly you still have the stock radiator?
After hearing about the all aluminum radiators failing I cancelled my order on the 4 row radiator. Now I wonder if I should have just kept it and installed. This truck only goes maybe 4,000 miles per year but many times that is towing where I have found the cooling system is below par for this engine.
Years ago I worked for Kool Klutch / Eaglemotive, they manufactured fan clutches and tranny coolers. I have installed many tranny coolers without having one leak yet, never had to jump to AN fittings but I do like them for quality and endurance. The Kool Klutch coolers came with good quality hose and quality stainless screw clamps. Properly installed they worked fine. Company was sold to Hayden in the mid 90's. Dayco was the company that owned Kool Klutch. Dayco also manufactured and sold a full line of Hydraulic hose and fittings and crimpers. Did lots of hydraulic hose work, it is nice to have background, helps avoid failures normally. Transmissions only see about 300 PSI, in the hydraulic world that is not high pressure so it is pretty easy to seal up? My experience is from 1980-1990 maybe the newer tranny's put out higher pressures? I have not stayed up to date. I spent the next 30 years working on the Engine side of manufacturing.
kbuskill
NE. FL.
Just as another point of reference, my Suburban sees about 20k miles per year on average. So the Cold Case Radiators last about 40k-60k miles on average, at least in my use case.
West 1
West 1
I ended up ordering a brand at Rockauto, CSF 3831, 1 1/4" thick core. Says it has improved cooling for HD use and towing. $175 delivered. I just got nervous, all the aluminum radiators seemed to show leak issues if you read all the reviews. I did choose not to buy the Mishimoto but it does look to be the very best available. Once I tow with the new Radiator I will update. I am adding the engine oil cooler also which should help. Thanks for all the information shared.
Edit: I do have one of the Kool Klutch Tranny coolers in my garage brand new, I may see if I can add that into the tranny cooler lines if I find a smart mount area that is out of the way. Probably wont get to install till next week.
j91z28d1
it's probably been said in this thread or around there alot. but the side of the radiator has air diverters that keep the air from bypassing the radiator. gm found something to make them out of the disintegrates over time. why they can't be plastic or something like everything else I don't know. it's like they go out of their way to find materials that's fall apart, when the one they use 6in away form it lasts. anyways, if you don't notice they are missing. I'm told it can make a big difference on interstate cooling.
West 1
West 1
I would need to see a good air diverter to know if mine is missing or damaged. I do understand what you are saying just have not seen the proper factory diverter you speak of.
I had a Camaro Iroc years ago, it had a small diverter under the radiator, looked like a small spoiler. That was knocked off by a curb. You could not drive that car on the freeway without it. Around town, zero overheat, on the highway temps would climb constant till you got off the highway. Replaced the spoiler and it was good as new again with zero overheats. Air has to move through the radiator for it to work and some cars/trucks need help to make that happen.
j91z28d1
there's threads about them with pics. I'll try to find. I remade mine out if old conveyor belt. they should last forever now.
these are on the side on the radiator between the head lights and the radiator support.
I know that 3rd Gen air dam well haha. kinda makes me wonder if one could do the same thing for these trucks. bit I don't tow enough to over heat and test it.
West 1
West 1
Thanks for that, I know what to look for now. They are either there and intact or long gone.
alexblagoev
Member Recommended
