Bought a 2010 Tahoe: Build Thread
Geotrash
Dave
Richmond, VA
Good job, papa! Looks like a nice ride to keep your family safe.
Oh, +1 for the 6.2 swap.
bfonz91
bfonz91
Last night I got my Intune i3 Diablesport tuner. Just loaded the canned "Diablo Tune" with the AFM delete. I'm impressed. Throttle response is way better, shifts are substantial, and it is significantly more fun to drive.
I know everyone swears by the DiabLew custom tunes, and I believe it, but this was just so simple and a no-brainer upgrade for now.
Oh yeah, and while it was connected, checked for codes. I'm clean as a whistle! Woot Woot
Miami-Dade
Nice work Blake!
mb1500
Sounds like a good plan, keep the updates coming.
Just Fishing
Can't fix stupid
Utah
If/when you go to install a backup camera.
The plastic trim piece above the plate where the license plate lights sit.
Seen a few with this problem, including prior owner of my hoe...
Apparently they use locktite on those mounting nuts/bolts
When you try and remove the bolts they can deform the bolts in the plastic cover.
I managed to fix mine, but i have some marine epoxy i used to form new mounts in the cover.
And i approve!
:cheers:
I have captain chairs in my hoe, but one of the former owners decided they wanted a bench there.
So they had a custom middle seat made, and they removed the arm rests.
I have yet to find a PN for just the arm rests so i can go back to full captain chairs.
bfonz91
bfonz91
Thanks for the heads up. I'll keep an eye out when I do the backup cam. Hopefully I'll get to it before Christmas!
bfonz91
bfonz91
Found out I had a leaky valve cover due to the busted gasket in the picture. So I decided to upgrade to the new style valve cover to fix the oil consumption issue. Hopefully this combined with the AFM delete (via tune) gives my mature 5.3 some extra life.
Just Fishing
Can't fix stupid
Utah
From my limited knowledge, i think you might have had the update valve covers already?
If not, it's on my list as well.
Not to mention to the time getting the crud/sludge off of them seems worth while.
bfonz91
bfonz91
No it was definitely the old style. (Round hole vs rectangle hole).
griffey_mojo
