Black Betty 2018 Z71 Silverado....build
went by the audio shop they are tied up for a couple weeks, so he gave me a print out to bypass via the amp output and a couple high/low adapters so I can get the amps in and everything working until I buy a aftermarket headunit when the price goes down then we can pull out the bose amp, the factory radio wont power on without the amp in place unless I use a $350 module which would end up not being needed after I swap the headunit later on.
Put the subwoofer cabinet feet on and wired and mounted the jl's wired it up for 1ohm, at least I hope I got it right lol
How does those subs being turned opposite directions not bother you?! Are you even human?!
lol, when I was making the wires to connect on the inside to the speaker I accidentally made one a little too short, the speakers are dual voice coil and wired for 1 ohm so the wires have to go a certain way. the speakers are going to be down-firing inside under the back seat so nobody will ever see them anyway
Looks like a big mess right now but I got the 0 gauge routed all the way and grounds are in, put in some more soundproofing on the back of the cab, ran out of light and time. all I need to do now is splice into the stock amp output and hook up my amps, test it, tune it and put the seats back in, amps are going to just sit back there for now until I get a headunitIMG_20200921_192329.jpg
Jim2014
