Black Betty 2018 Z71 Silverado....build
went by the audio shop they are tied up for a couple weeks, so he gave me a print out to bypass via the amp output and a couple high/low adapters so I can get the amps in and everything working until I buy a aftermarket headunit when the price goes down then we can pull out the bose amp, the factory radio wont power on without the amp in place unless I use a $350 module which would end up not being needed after I swap the headunit later on.
The sundown 2.75" dash speakers are in, tight spot but workable with a small ratchet
Put the subwoofer cabinet feet on and wired and mounted the jl's wired it up for 1ohm, at least I hope I got it right lol
How does those subs being turned opposite directions not bother you?! Are you even human?!
lol, when I was making the wires to connect on the inside to the speaker I accidentally made one a little too short, the speakers are dual voice coil and wired for 1 ohm so the wires have to go a certain way. the speakers are going to be down-firing inside under the back seat so nobody will ever see them anyway
Looks like a big mess right now but I got the 0 gauge routed all the way and grounds are in, put in some more soundproofing on the back of the cab, ran out of light and time. all I need to do now is splice into the stock amp output and hook up my amps, test it, tune it and put the seats back in, amps are going to just sit back there for now until I get a headunit
Let's see what did I do today, wired up the amps. got the dash speakers working, got the front door speakers working, got the rear door speakers working. great!
Then I proceeded to the subs and nada, barely any sound, screwed around with for a while and then discovered I had wired the subs wrong and had pretty much instantly fried the voice coils :emotions122::emotions122::emotions122:
so my happy ass went out and bought 2 more subs, wired them in correctly, hooked up the amp had happytime for about 10 minutes and then the amp blew up, like blew up blew up,
smoked it like a bbq :evil27::evil27::evil27: so I grabbed a spare amp I had that was supposed to be working just to have some sound for now and.....no output from the radio
screwed around and tested every fuse because the radio was fuse was fine and amp fuse was fine, after I checked every single fuse I turned on the radio and I have output WTF!!!
so I start adjusting the spare sub amp flip a switch and bam it blows both fuses...... ****
so I guess I am on the hunt for another amp tomorrow locally...
maybe from having the subs wired wrong I killed the first amp, I don't know, all I know is that is it's dam near $1000.00 down the drain. :boxed:
Thouse
this is why audio stuff scares me! I hope you catch a break.
wjburken
Eastern Iowa
I’m rooting for you!
That SUUUXXXX!!!
How were the subs wired wrong? Just so I don't make the same mistake.
That SUUUXXXX!!!
I followed the diagram in the manual which showed the "JL" on the back of the speaker facing up, on the diagram it shows positive-to-positive being vertical to each other but they are in fact diagonal, rookie mistake I thought I might have done it wrong but didn't double check and didn't think it would fry the coils but they are done smells like typical burnt electronics:(
lol, should have seen me running to disconnect the power wire from the battery when the amp blew, once in the late 80's I had hooked up a amp and speakers and was with some friends just cruising down the road and suddenly the entire car filled with smoke, like cheech n chong up in smoke! managed to pull over and found the entire power wire had burned from the battery to the trunk and fried the carpet with it, just a big black burn mark from front to back it was the weirdest thing.
This was all new stuff?
wjburken
Eastern Iowa
:happy175:
Love that movie - great visualization as well. Did you also have the welded chain steering wheel?
:happy175:
haha, no it was a 80's chevy cavalier, man I abused that car so bad... I melted 3 sets of spark plug wires to the engine because I didn't fix the bad water pump and kept driving it. That was a bad turning point in my life I went from having everything I needed a good job my own place and transportation, to having nothing and being homeless, that's what Meth will do to you.
Hodmjstone
