Big brakes on obs?
danstowers82
Looking for a cheap way or a kit to put bigger rotors on my obs tahoe. I was told by ssbc that it can't be done since the caliper bolts directly to the spidle. Anyone upgraded rotors without spending 1000+ dollars????
Sent from my SPH-L710 using Tapatalk 2
njJohn
Aberdeen, MD
I think later spindles fit as long as you ream the upper balljoint hole. Bigger than 16" wheels are needed.
danstowers82
danstowers82
Thanks man. I have 26's so I think they should clear...lol. you know anyone who has done that?
danstowers82
danstowers82
Cool. Thanks. Think I'm gonna have my buddy cnc me some adapters for c5 vette calipers.
danstowers82
danstowers82
Awesome link! I'm doing it.
---------- Post added at 10:22 AM ---------- Previous post was at 10:21 AM ----------
I'm going to do a 2wd also.
nastynate
Finally found your ass! And they tens get it right! Haha
Sent from my SPH-D710 using Tapatalk 4 Beta
danstowers82
danstowers82
They 10's...they clean though!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
ssbc has bigger brake sets for the 2wd with bigger rotors and 4 piston calipers but only offer dual piston calipers for the fronts on 4wd with no increase in rotor size.
danstowers82
danstowers82
Ssbc prices are ridiculous. Bigger rotors have more leverage and make less heat as I'm sure you know so bigger calipers on stock size rotors are pointless in my opinion.
nastynate
Not to mention ssbc looks like crap..all that money for some donky ass breaks..f that..just my opinion:D
Sent from my SPH-D710 using Tapatalk 2
danstowers82
danstowers82
I can get the entire front brake setup off a 2000 Z71 (12in rotors) and the tool to ream the ball joint for significantly less than what SSBC wants just for calipers.
SunlitComet
OBS Jedi-Do Good
cost is high but remember then are machining billet aluminum block to get what they want. still can be a bit cheaper but they are not flying off the shelf so until then prices will be higher.
danstowers82
danstowers82
Aluminum is cheap and they just run it through a CNC. cheap to make and they charge too much in my opinion. Big calipers on 10" rotors don't look good on a truck. ;)
danstowers82
danstowers82
Wow. 11.6 I'm sorry. An inch makes a huge difference in looks on a 26" wheel, wait a minute, no it doesn't. I want to do Z06 vette brakes. I'm in the process of doing it now.
PexoA78
