anybody realize power loss at take off?
drowndindreams
Unknown
Lately I have been realizing that there has been a significant amount of power loss, or acceleration problems at take off. If I'm looking at a tune up, what should I be tuning up? What other things can I take a look at that have to do with the acceleration?
Thanks TYFers
MUDDER TRUCKER
port huron,mi
im not sure, when was the last time u changed ur plugs? , mine loses power at 70 then climbes back up for some reason
Nickleahy23
Portage/Menomonie, WI
Thanks TYFers
get ahold of justin at blackbear performance..hes a vender here..best mod for the money
clean454
egr?? unplug the line going to the egr and see if it runs better
i had this problem i did all kinds of stuff to my hoe then come to find out it was a bad egr valve
blueflamed03
Oklahoma
clogging fuel filter? How many miles on truck? Stock wires, plugs, fuel filter?
Is this a recent change?
drowndindreams
drowndindreams
Unknown
AC Delco plugs put in at around 120-140K (now at 172K), replaced wires with them,
but the fuel filter was recently replaced by a used but newer same model - figured I'd save the money. Think that'd be it?
I've noticed it very recently, within 3 or 4 weeks I'd say.
black95
Freeport,NY
i am alos experiencing lets say a "loss of balls" lately , going to try a standrad tune up with a fuel filter hopefully that helps. even though the last tune up was in may 09 7,000 miles ago (acdelco plugs , new wires(kind of cheap), car and rotor )
haks310
Got LEDs?
SoCal
Do not skimp on the wires. I have seen first hand what cheap wires can do. Replace the PCV valve too. Clean out the TB and check the EGR valve.
black95
Freeport,NY
i know for sure my egr is ****** . i drive around with it unplugged. it you leave it pluggged in it runs like it has a cam at 1500 - 2000, but unplugged it wasnt too bad . now it is slow as shit. it is a 95 so no tune for me.
foreverfalcon40
Used Fuel Filter....are you ***** serious? Things are less then $20 bux. A clogged up fuel filter will cause your fuel pump to burn out and you'll be out mucho money for fuel pump and labor!
haks310
Got LEDs?
SoCal
Fastchip. You can get your EGR tuned out.
LoL used fuel filter, wtf?! They're around $12. I change mine out every 15K just for preventative maintenance. But they should be done at least every 60K miles.
black95
Freeport,NY
i want the fast chip. but doesnt the egr limit the heat of the exhaust so it doesnt go over 1000degrees fahrenheit, so what would i sacrifice tuning it out?
blueflamed03
Oklahoma
Leave it up to Ed, he's semi local to me, been doing this for years, and is an avid racer. So he knows how to tune the pre 96's.
puckhead
CO
Wheres the egr at any way? lol sorry for the ignorance. does unpluggin it mess with anything else? any bad side effects?
BlacktopBandit76
