My 2007 Yukon had a low idle miss at 93K miles on the meter. The cylinder with the miss had a really fouled plug. It had been using about a quart of oil every 2K miles or so, which I assumed was worn rings.
To diagnose the miss, the dealer started with the PCV, moved to the down rev valve cover (which they swapped out along with a decarbonization procedure) and eventually ended up replacing all eight pistons, rings, etc. GM stepped up with the parts and my dealer did me a good turn on the labor, so I got fixed what seems to be an AFM related design issue, pretty inexpensively.
Fast forward a few years and 30K miles and the engine still runs like a top, no oil consumption between oil changes, etc.
The more I read about the AFM issue, the more I am thinking a couple hundred bucks to shut AFM off (with a Range Tech ODB plug) even though I have the updated valve cover, new pistons/rings, etc., seems like a small price to pay to avoid this issue completely say 70K down the road from here.
Opinions on the above logic are greatly appreciated.
