chaingun427
OBS Mad Scientist
The title says it all folks. I've priced the difference between the HT383e, Blueprint engines 383 short block, and building my own, and doing it myself just makes more financial sense so I'm going to document my process, progress, and see if anyone has tips or advice on this build.
I'm putting together a spreadsheet of parts for this build that i'll be glad to share if requested. The basics are as follows
1. Cleaning of block, intake, throttlebody, and heads, clearancing & boring .030 over, valve job, and port&polish $500ish (not sure about having it made into a 4bolt probably more expensive than it's worth for a sub 400hp motor
2. Eagle balanced Rotating assembly B13405L03068
3.750 stroke, forged rods, perfect circle rings
$799 at summitracing.com
3. GM cam 14097395
lift 196 int./206 exh. duration 288 int./308 exh.
Same as the HT383e, should work with factory lifters and (new) factory springs. Mild cam, but should work well for a DD, occasional towing.
$168
4. Pace Setter 72C1320 short tube headers
good for low end torque, and a factory like exhaust system
(not sure if i'm going to do a magnaflow headerback system, or complete custom system I want a nice throaty sound when I get on it, but quieter at highway speeds)
$399 for chrome
with additional parts including all ARP head and main bolts, new timing set, and a master gasket kit i'm looking at roughly 2280 (+incidental costs like oil, filters, assembly lube etc etc)
Today I'll be cleaning up my garage/workshed so that i'm able to have a place to rebuild the motor and transmission.
One thing I was told was possible, is to put a 7.4l 80mm throttle body on the 350 intake, has anyone done that?
3. GM cam 14097395
$168
$399 for chrome
