2012 Yukon Denali - 6.2 lifter or something else? [Advice/How to Proceed]
Pointer 21
Good morning - Dreading to even start this post as I haven't had to engage this forum with what I think (hope not) is this biggest issue I've had yet:
2012 Yukon AWD Denali 6.2 (Original Owner),
**165k miles w/trans and rear main seal replaced at 152k in 9/2021
Oil Changed every 5k, mainly city driving
At the time of replacing the tranny I had numerous issues to address (really maintenance/suspension); however, there was an oil leak from the rear main seal (at least I thought) at that time in which I figured I'd have the rear main seal replaced while tackling the transmission. (This wasn't the case - I still have a slight leak around the transfer case that wasn't addressed.
Fast forward - 18 months/15k miles, I'm having my oil changed and I'm 2 quarts low per the oil change kid after me quizzing him.....(alarming however, it had been sitting and I had been monitoring it prior, so I didn't freak out).
One day after the oil change (15 city miles and leaving the car wash) I hear something slightly noisy in the motor and lose power at take off. Sounds minor maybe a belt...took a slow drive home. Pop the hood and it sounds more like a rod knock..... It gets louder as you rev the engine. I emphasize the car wash and oil change bc its an odd sequence and prior to popping the hood I'm thinking wet belt something minor HOPEFULLY NOT WATER IN THE OIL....
I parked it and haven't driven it since (so it was only driven 5 miles slowly after the noticeable issue). I realize a Tech 2 (i don't have) and proper diagnosis would help give clarity here but wanted some insight/trouble shooting/info on how to proceed from the gang.....
Any input is much appreciated - I'm charting into territory I did not see coming nor am I well versed in...hoping there's some light at the end of this tunnel.
Thanks!
Geotrash
Dave
Richmond, VA
Thanks!
Best thing to do is record a video with your mobile phone of the noise, upload it to YouTube with public permissions and link it back here. We'll give it a listen and go from there.
Also, is it safe to assume that you checked the oil after this and it's still topped up? A stuck or damaged lifter can sound like a rod knock but a rod knock is at the same frequency as crankshaft rotation, and a lifter tick (or exhaust manifold leak) are at a frequency of half crank rotation speed (slower).
To start with check your oil level first and look at the condition of the engine oil cooler lines going into the radiator on driver's side. Weeping is ok, leaking is not.
If those check out, get something you can use as a stethoscope, like a long extension. Fire up the motor and let it idle and look for the source of the sound. Believe it or not, an exhaust leak can sound like a rod knock, had it happen to me. Happened when the kids spilled too much oil filling it up and then started the engine with all that oil on the manifold. Oil change place or car wash place "might" have done the same thing. And do what Dave says!
P
Pointer 21
WELP - It got very interesting. I checked the oil and cooler lines (these arent in great shape as I did have a bit of oil on my hands inspecting them). Sent a video to a mechanically inclined buddy who said "that my friend is a rod knock OR LIFTERS"...told me to check the oil and see where it's at (His synopsis was the Oil change place caused this).
I went to check the oil again...issue STOPPED. Ok great....drive around the block (engine light, stabilizer off, traction control off) THIS HAS NEVER HAPPENED BEFORE.
Things to consider - I did a 2.5 level, with a 1.5 block in the back.......It's been running like a dream.
WRONG OIL FILTER? Extended lines from the "2.5 level"?? No clue...I guess a tow into the shop is the best option.
ALL that considered....I have a trust worthy regular ole, mechanic with a nice shop...not necessarily a GM guy, can he tell me his thoughts OR should I go GM specific? My thought is that IF this is the worst case scenario, I'll be Deleting the AFM, chipping, etc...what to do, what to do???
Geotrash
Dave
Richmond, VA
Thanks for the update. Just to make sure I understand, when you say stopped, do you mean that the knocking sound went away along with all the indications, or did you mean that the engine stopped? And was the oil level okay?
If the sound went away and the oil level was okay, I would be inclined to just drive it. It’s not unheard of for a lifter to get stuck for a while and start functioning properly again… assuming that’s what it was. We don’t know because we still don’t have a video.
My hypothesis is that assuming the oil level was fine, that the sound went away and that if a lifter was indeed the problem (most likely), that a lifter stuck in the cylinder deactivate position for a while and then unstuck itself. If so, I would have the AFM system tuned out as soon as possible - either programmatically or with a Range device.
The leveling kit had nothing to do with it. And in my experience, most any shop has experience with these engines and problems now. They’re one of the most common powertrains on the road.
P
Pointer 21
To clarify - The “knocking” happened late Saturday (last weekend). There was no check engine light and it was uneventful until I popped the hood and started connecting the dots. Yesterday (after this post) I checked the oil which was OK, looked under the vehicle which had leaking oil around the filter and was chalking it up to a lifter issue. Moved the vehicle to level ground to check the oil again and the noise is GONE! I’m thinking I’m being warned here and yes - delete ASAP. I drive about a 1/4 mile and the traction control, engine light, etc all kicks on (this hadn’t happened yet). I was nervous about driving it home and was going to have it towed about 1 mile from where I stopped to my house (I ended up driving it back) - hope I didn’t cause more damage here.
Anyhow - I’ve got a check engine light (which even auto zones deal can read that code). Obviously a lot of variables here but if this does end up being the worst case scenario I’d imagine I’d want to do a lot of “while you’re in there work” including addressing the issues and future issues which is why I want to get to a shop that will work with me (would that be a performance shop)?
Any tips and/or if the “while you’re in there” is applicable and/or advisable or if I’m over thinking it is much appreciated.
If I need to cut bait and run - please lay that on me too! I’m not a happy camper with this costly vehicle right now….
Geotrash
Dave
Richmond, VA
Thanks for clarifying. I get it - you rely on this vehicle, don't yet know what you're up against, and without more certainty you don't want to make things worse.
Yes, I think you have received a warning from the AFM system that it's time to take some sort of action (sure would appreciate a copy of that video to be certain - happy to PM you my mobile # if you don't want to upload to YouTube). But at any rate, here would be my courses of action if I were in your shoes. (Understanding also that I have done a mechanical AFM delete on my 2012 XL Denali in my garage so I know first-hand what that entails).
1/ Electronically disabling the AFM system - either through a tune or with a Range device will make your valvetrain as reliable as a regular non-AFM valvetrain. I would prefer a tune for this to make the change permanent. There are a few ways to go for this; a) a tune from @BlackBearPerf will do many things, including wake up the performance of your engine and transmission without sacrificing reliability or durability for about $700. Or b) send your ECM out to a guy that @iamdub knows about and have AFM turned off for about $50. Or c) Buy a tuner like Diablo Sport or HP Tuners and learn to do it all yourself.
2/ Mechanically deleting the AFM system - this will cost anywhere from $2500 - $5000 depending on how deep you go, but you can get a bigger cam to boost performance if you wish or stay with a factory cam profile but either way the cam will have to come out. New lifters, valve stem seals, etc etc.
Personally, if I had this to do all over again, I would just disable the AFM system with a Black Bear Tune and party on. But if you're looking for self-torture and feel like tackling this yourself, here is my story to help guide you:
P
Pointer 21
As always many thanks imparting the vast knowledge. For efficiency I sent you a message but will upload the video to the thread for other members knowledge (pressed for time in trying to figure out YouTube)!!
Geotrash
Dave
Richmond, VA
Appears to be a lifter issue......Where and how far to go with this is the question at hand.
100% stuck lifter but doesn't sound to my ear like it's eating the cam yet.
Based on our terrific text exchange it looks like your priority is for it to remain a reliable daily driver and you will pay someone else to do the work. With that, I see three options:
1/ Cheapest: try the Crazed Performance lifter trick and see if you can get the lifter unstuck. If you can, immediately have the AFM tuned out with a $50 mail-your-ECM tune, and drive it like you stole it until the wheels fall off. Probably $150 for the tool and the tune, plus your time. If you can find a shop to try the Crazed Performance trick for you, all the better. Probably $500 in labor to give it a try.
2/ Next cheapest: Have a shop identify which lifter failed and replace it along with the lifter trays on that bank. Requires pulling one cylinder head. Probably $1500 in parts and labor.
3/ Fancy: Have a shop install a DoD delete kit from Texas Speed or do like I did and roll your own from the parts you want. This will include a new cam (mild or wild, your choice) and timing set, new lifters and springs, new flat valley pan, new OEM lifter trays and some other doo dads. Probably $3500-$5000 in parts and labor. I would still prefer a Blackbear tune over a local shop, though. Justin knows his shit.
What would I do? Pack a couple of lunches and a cooler of beer, then spend the weekend doing option 3. If I was long on cash and short on time, I would pay a performance shop to do option 3 to my specs.
For a Hail Mary, you can run some marvel mystery oil in there for a few hundred miles. @Trey Hardy fixed his stuck lifter that way a couple of times now.
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
This is good information, and we would be happy to help with a tune.
P
Pointer 21
You hit the nail on the head - my trust worthy mechanic (NOT A PERFORMANCE SHOP) just texted me and said it would likely be a $1000-$1500 fix. I haven't verbally spoken to him (it was his wife texting) so I'm not sure of his exact process - It'll likely be what you'd expect from a good mom/pop shop so option #2.
Any other input on "maintenance items" at 165k miles? I was thinking 02 sensors? oh yeah - the transfer case will have to be removed to address the oil leak on the passenger side as well.....JUST $$$$$. GRRRRRR
P
Pointer 21
@Geotrash @swathdiver - I appreciate the heck out of ya'll. I want to mirror Dave's approach of turning this 6.2 into a racecar but in all honesty I'm still concerned there may be underlying issues that I've either neglected over the years or hell I flat out don't understand....Prolly time to get a Tech 2
At about 60K miles my acceleration/power/mpgs went down and the cats started having a funky sound.....I've never gotten over 13 mpgs with OEM 22's (all stock, 93 fuel, synthetic oil every 5k). Looking back the cost of ownership on this thing has been expensive....
Suspension - ALL OEM (Thanks @swathdiver for the help here)
Transmission - Replaced (Still nervous that it wasn't rebuilt properly)
For fun - recently 2.5 level, 1.5 R, 33 tires (TERRIBLE GAS MILEAGE)
To keep it simple, reliable, extra pep or just how it came stock (bonus if I can get MPG's) what's my best course of action? Tune, AFM delete, and exhaust mod/delete (not clear here)?
I appreciate the input - I'm trying to instruct my mechanic on what I want him to do and will be having it towed in the AM....
The cheap AFM disable "tune' Dave was referencing is at https://lt1swap.com/afm_delete.htm. You mail them your PCM (at your cost- maybe $10?) and they'll disable AFM in the tune and mail the PCM back to you for $50. If you're gonna do an AFM delete, you'll need it disabled in the tune, anyway. This would be the cheapest way to JUST turn off AFM if you wanted to remain stock otherwise.
I'll echo Dave's recommendation on having a full tune done if it's in the cards for you. In stock form, these things have plenty to clean up in the tune. It's not so much as a lot of power production left on the table as it is efficiently getting the power it already makes to the ground. This vastly improves the drivability but reducing the confusion in shifts really helps the transmission. It's a win-win. As Dave and others have said, Black Bear Performance have proven time after time that they know what they're doing with these things.
P
Pointer 21
Appreciate the feedback and excuse my ignorance here. Is the process to have the lifter unstuck and then delete the AFM system? Therefore I wouldn’t need extra parts and I would keep rolling?
I’m thinking that a @BlackBearPerf will be purchased; however, I want to make sure the vehicle is performing optimally before tuning.
I’d assume I’ll have a few days down while I wait for the tune or delete?
Geotrash
Dave
Richmond, VA
Yes, that's correct except there is of course a difference between mechanically deleting the AFM system and simply deactivating it with a tune.
If you can get the lifter unstuck with the Crazed Performance trick, then you can leave your AFM hardware as is, get the Autocal device from Black Bear, log data using the 20-30 minute drive cycle they prescribe, send them the ECM and TCM files that the Autocal captures, and they will send you back customized tune files to install with the Autocal that are based on your truck's data, and not simply a canned tune. Very important distinction. And of course they will deactivate AFM as well at the same time.
On the other hand, if you decide to mechanically delete the AFM hardware after all and want to install a larger cam as I did, then all you have to do is send Black Bear the cam specs and they will send you back a new tune to get you up and running so that you can log some more data, send it to them, and they will make the final tweaks. It's a great process.
In my case, the cam I chose is a 3-bolt cam (no VVT), so I had Black Bear deactivate VVT as well and in my case I haven't missed it.
Geotrash
Dave
Richmond, VA
I consider 165K to be 'midlife' on these trucks. So if yours is still a rust-free example, it's generally worth it to invest some money at this stage to bring the whole thing back to tip-top in terms of long-term reliability. $10K is still about $70K less than buying a new equivalent truck.
Assuming that your AFM delete kit comes with new lifters, valve springs, valve stem seals, etc, on *my* list of additional things I'd do if I were having a mechanical AFM delete done would be: (And yes I know that you've had some of these things done already)
Engine:
1/ New water pump and thermostat (OEM only)
2/ New Denso radiator (Denso is the OEM manufacturer)
3/ All new coolant and heater hoses and connectors
4/ New cooling fan motors
5/ New oil pump pickup tube o-ring
6/ Replace the oil pressure sensor (OEM only) and delete the screen under it.
7/ Replace the oil pressure relief valve in the oil pan, or better yet - plug it. It's no longer needed without AFM.
8/ New coolant temp sensor (OEM only)
9/ New plugs and wires
10/ New belts, idler pulleys and tensioner.
Other engine compartment and transmission items to do at midlife:
1/ Replace the torque converter in the transmission with one that has a billet cover and stronger lockup clutch. Do the rear main seal at the same time along with the oil gallery barbell at the back of the engine as they can sometimes bleed off oil pressure later in life.
2/ Replace both motor mounts
3/ Replace engine oil cooler hoses
4/ Replace transmission fluid cooler hoses
5/ Replace power steering high pressure hose
6/ New alternator
This is WAY more than most people would do. But I plan to run both of our trucks for at least another 10 years, so the investment is worth it to me. That, and I really like knowing that I have a 99.999% chance of getting where I'm going. :cool:
P
Pointer 21
***On the other hand, if you decide to mechanically delete the AFM hardware after all and want to install a larger cam as I did, then all you have to do is send Black Bear the cam specs and they will send you back a new tune to get you up and running so that you can log some more data, send it to them, and they will make the final tweaks. It's a great process.
Ok - things are moving fast and I'm KINDA picking up the process; however, my mechanic is saying he would "simply replace all the deactivation lifters with regular lifters for me to deactivate the system. A stuck lifter is never worked on to get unstuck. It is always replaced".
I had a hunch he wasn't going to go with my internet PHD here and he's not a performance shop....HA HA
Ya'll can e slap me but what is the process that makes the most sense? I'm sure there is an advantage to mechanically deleting but I'm sure that has a price as well.....If we're trying to get this unstuck and delete with a black bear tune...How do you get the vehicle running with a messed up lifter? I might need to find a performance shop or the little ghetto ones down the street for the gangster moves??
Geotrash
Dave
Richmond, VA
Yeah, so your mechanic seems to know nothing of the Crazed Performance process for getting the lifter unstuck and wants to do a mechanical delete because that's what he knows. That's fine. I shared the info about unsticking the lifter in case you were willing to take a crack at it yourself but perhaps not, and that's fine too it just means you're in for around $2-3K just for the AFM delete. If you do decide to try to unstick the lifter and you're successful, then it should run just fine while you do the data logging for the Blackbear tune.
But if that's just not something you want to try, then the only process I see for you is paying your mechanic to do a mechanical delete, followed by a tune. Hopefully he also knows that he'll need to replace the cam also. @swathdiver knows the correct part number for the GM factory cam that has the same spec as your existing cam, including VVT, but doesn't have the AFM profiles. Essentially it would be the same as the factory cam for the L92. Or you can upgrade to a more aggressive cam. Either way, presumably the shop would also have the ability to tune out the AFM in order to get you up and running again (it won't run right with a non-AFM cam if the AFM is still active in the tune). Then you could do a follow-up performance tune through Blackbear which is still well worth it.
P
Pointer 21
You've created a beast:
https://www.texas-speed.com/p-7379-...ce-dod-afm-delete-kit-for-536062-engines.aspx
Here's the deal I don't want to cut any corners and want it all done right. I just spoke with black bear and we're putting our heads together.
The mechanic, myself, or another shop will do what I want....I need to figure that part out. Will the vehicle run with an "unstuck" lifter? I'm in over my head...
dizhai
