2011 Tahoe squeaking
Rummel6
Just purchased this Tahoe with 178k and one owner with maticulas Maint record I have a squeak it’s coming from the back of the motor and cannot he heard until the motor heats up I have already replaced idler pulley,water pump,tensioner,power steering pump and alternator so there not the problem here is the video
Took it to dealer and they said rear main seal but want over 1600 to fix anyone have any ideas
Take the belt off and try spinning the pulleys by hand to find the noisy one, you could also try a set of stethoscope from the auto parts store there cheap. or just use a hollow metal tube as a tip piece and a length of rubber line held to your ear
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
What Wes said, Steve said and Wade said. In over 35+ years in a shop I have never heard a rear main seal make a noise and that noise sounds like up front and not at the rear. One inexpensive tool all owners should have is a mechanic's stethoscope. A few others come to mind but are just a little bit more money but they save time.
Rummel6
Rummel6
So the dealership removed both belts and noise is still there also I have the metal stethoscope and so confirmed it is coming from the area between the engine and torque converter is located
Rummel6
Rummel6
Also like I said when the motor is cold no sound has to heat up and above 1500rpm when revving you can’t hear it that why I’m so puzzled on what it is
Rummel6
Rummel6
Also realized when I changed the oil two days ago there was oil on the back side of the engine around where the filter is so I assume it was loose but it wasn’t had to use tools to get it off now the dealership said there 80% sure it’s a main bearing but not sure to trust them cause they also said I have metal in the oil and I didn’t see anything in the drained oil or on the magnetic tip of the drain plug
OR VietVet
Willamette Valley
Look, I get it but I just never heard of such a thing. Doesn't mean it cannot happen but man, that would be a new one on me. Is your oil pressure in the normal range?
So I went searching for another time this has happened. Listen to this video:
This was on a Bronco but sounds the same. I like Fel-Pro if you go this was. https://www.rockauto.com/en/moreinfo.php?pk=447129&cc=3015551&jsn=2290 For the whole kit.
Or a 2 piece AC Delco with this: https://www.rockauto.com/en/moreinfo.php?pk=6437253&cc=3015551&jsn=2291 and this: https://www.rockauto.com/en/moreinfo.php?pk=9838924&cc=3015551&jsn=2293
You could also take apart and shove grease in there, like in the video but you said it was wet with oil back there so I would do the replacement.
It means pulling the trans and torque converter down and removing the flex plate and then the cover. If you have jack stands, floor jack, tools and a mechanically inclined friend and watch 2-3 videos of it, it is not that difficult.
This, like the guy in the video said, is something I have never ever heard of before.
Sounds like a pulley to me, got louder when you put camera in front and towards passenger side. I would stick the stethoscope right onto the moving pulleys and have a listen. One time I melted a piston in a drag race and it sounded similar though higher in pitch. Start with the simple stuff!
OR VietVet
Willamette Valley
Dealership removed both belts and noise was still there? Same dealership that said the rear main seal was the noise? Same dealership that switched that to rear bearing? Were you standing there when the noise was still there when both belts off and engine was running?
Rummel6
Rummel6
No unfortunately I’m out of town for work yeah not to confident in them so far
Rummel6
Rummel6
Just talked to them so there saying it’s the main bearing that’s causing the noise but besides the squeak the motor runs very smooth I’m just gonna have my buddy look at it and let me know what it is
OR VietVet
Willamette Valley
I would not let the dealer tear it down yet. Good that the buddy is going to look at it. Personally, I would not have let the dealer look at it while you were out of town. No way for you to be there for proof. Too many shady stories on this forum about dealers and some of their techs.
Rummel6
Rummel6
Yeah guess I have to eat 300 but I can guarantee if it’s not what they said I’ll be hitting them in small claims court for that money back and lying
OR VietVet
Willamette Valley
Keep us all informed as to what happens on this after you get back in town. I am really interested in this thread.
Rummel6
Rummel6
So my buddy that builds race motors verified it’s a bad lifter that’s going bad so guess we are tearing it town he said where gonna do lifters and a cam also any suggestions
OR VietVet
Willamette Valley
So, went from a rear main seal and rear bearing squeak to a lifter squeak? Correct? How did he verify that? I am in no way doubting his diagnosis but I am very curious about how he came to that decision.
Rummel6
Rummel6
So he started in the rear where the dealership said the noise was coming from and disconnected the flywheel to verify if it was the engine or trans sound was coming from engine then pulled the covers and started tearing it down can’t remember if he said it’s collapsed or it turned I know he said I need new lifters and possibly a cam hasn’t got that out yet
OR VietVet
Willamette Valley
Ok, a collapsed lifter noise and the squeak noise are vastly different from each other. I HOPE it fixes the noise but I am still very curious about this. What do you mean by "collapsed or it turned"? What did he say was the reason for needing new lifters? If I was keeping the rig I would do the cam at the same time as the lifters anyway.
TallHoe 96 OBS
