@imadub - the oil pressure is funky, it used to always be around 48-52 at 2,500 rpm and 25-30 at idle but this winter it had a heck of a time holding oil pressure. Now that it has warmed up it hold 15-18 at idle and 30-32 at 2,500 rpm. I am thinking the oil pick-up seal is cooked, also weak oil pump all due to miles. I did try and fill it with another coupel quarts of oil and tried to find an incline to see if the oil pressure increased. It did slightly, however, I am not sure I was on enough of an incline either.
The reason for replacement of the timing gear/chain, I am getting the code P0016. I don't have any analysis tools but its pretty hard to start and once it does it runs kind of rough. I guess I was thinking the tensioner probably crapped out but I am not hearing any extraordinary noise though? I did take a breaker bar and socket to tried to move things to see if there was much play and there seem to be some, maybe 1/2 inch - I know not very scientific but...
I thought about it being a crank sensor also and entertained the idea of replacing it to see, heck of a lot less work than the timing chain project.
Anyway, long winded response to your question.
Thanks,
Tim
