2001 Tahoe REAR Passenger Water Leak
Partsguy19
Hi All,
Hoping for some help/suggestions. The floorboard on the drivers side rear passenger area is getting wet (very wet). I can't find any other area in the vehicle getting wet. Headliner is dry. Could it be as simple as a door seal? If it was a door seal I wouldn't think it would be wet towards the center and close to the tire changing tools.
Thanks for any suggestions.
You say 'rear passenger area'. Are we talking about the 3rd row seat? Do you have a rear AC unit? If yes, it is possible that the condensate hose is plugged or has become disconnected at the AC unit area, which should be in the rear right siding area.
S33k3r
Dallas, Texas
If you aren't referencing the third row/are referencing the second row, is it near the center console? I had an AC/water leak that went all the way from the front to the very back of my Escalade ESV. In your case it could be going along the center console so you only see it in the second row.
EDIT: "center" only has 2 e's in it, not 3...
j_jerry79
