1 quart low after 3,000 miles
ekordas
So my 2002 5.3L has gone through about a quart of oil since the last oil change. The check engine oil level light came on today and the dipstick was pretty dry. Pretty sure my sending unit is bad considering my oil pressure needle shakes like crazy at idle. Anyone have possible causes of oil loss? No leaks on the garage floor but getting some drip marks coming down towards the oil filter possibly from the back of the engine. I'm wondering if my sending unit is actually starting to leak once the engine is running, so I could be leaving my oil on the road and not on my garage floor where I can see it. Any advice? Common spots for oil loss? She's been well maintained since brand new. I switched to synthetic oil a couple oil changes ago, maybe it's too thin for a truck with 150k on it. Definitely switching back to regular motor oil to prevent fast oil loss. I don't think she's burning it. No dark smoke out of the tailpipes. If anything it might have a slight white smoke coming from the pipes.
Hooch
Pretty common with the 5.3 motor. If you are in a warner climate try some Rotella 15-40 oil. See if that makes a differense
doylee4693
Tahoe User
New York
Try changing youre pcv valve. If you havent changed it before then upgrade it to a fixed orrifice pcv valve and see if that helps.
dmperfection
Azusa, CA
My '02 Tahoe 5.3L with 208k miles is losing about a quart every 2k miles and from what I understand, is acceptable. I've been using 5/30 Mobil 1 full synthetic for high mileage for the last four years, and in the last year started adding just a tad bit of Lucas oil stabilizer. The Lucas seems to slow down the consumption just a bit. However, I did start seeing the same leak you have going on; from above the oil filter that comes down the sides of the oil filter. Also, I've recently started seeing my oil pressure guage start to quiver a little at idle, but goes back to smooth when rolling--I plan to ask the oil pressure quiver on a new thread.
Screwd up 6
I have a 2002 5.3 with 123K on it, I noticed my light came on as well almost exactly at 3K miles. I called up a friend of mine that is a certified mechanic that has a 5.3 as well. He said all of his 5.3Ls have used more oil than what is normally expected. I was told, if there is no noticeable leak, that 1qt is not anything to worry about every 3K. He said given the mileage and that the 5.3L is notorious for using oil, I dont need to worry.
03z71chevy
Buford, GA
My research has also suggested these engines drink oil. My 03 with 230K uses at least a quart every 2K miles. That's running royal purple. I also have never noticed any smoke which I am glad about but seems odd.
yukonese
1 quart loss between oil change
My Yukon (2001 5.3L, 75k miles) started to lose 1 quart of oil when it's time to change oil (about 6k miles interval) two years ago, there is no any oil leak on the ground, no smoke from the pipe either.
The smog check looks fine too, here are the numbers:
15mph@1353RPM 15% CO2 0% O2 4PPM HC 0.01% CO 0PPM NO
25mph@1367RPM 15% CO2 0% O2 3PPM HC 0.01% CO 0PPM NO
The minimum requirement for 2011 California standard is
15mph 101PPM HC 0.57% CO 980PPM NO
25mph 90PPM HC 1% CO 840PPM NO
I kind of doubt the cheap O'Rielly motor oil is the root cause, because this problem happened after I used this oil. Of cause, I switched to name brand synthetic motor oil afterwards.
Where does that quart go? Any inexpensive treatment (Slick 50) works? Thanks.
doylee4693
Tahoe User
New York
Guys this is not a common issue with these motors so please stop saying that (unless its due to high mileage). Did anyone of you even bother checking your pcv valve as ive suggested instead of "broken is how its supposed to be" sort of attitude. It might actually work you know just a heads up.
livingez_123
Sandy, OR
I'm a Amsoil dealer and I have been told by many higher ups and customers, if you have a weak seal or gasket synthetic oil will find it and if you never burn oil with regular dino oil you might notice some usage with the synthetic oil. if you build a new engine and start with synthetic you won't have an issue with leakage or useage.
yukonese
OK, worth a try!
Bought a fixed orifice PCV for $.99, it is the updated one for 03 and beyond, I heard it is OK for 01 Yukon.
There is nothing but a fixed orifice at the bottom in this PCV, don't know why it can replace the original spring plug one. For this simple design, if you pay more than one dollar, you pay too much.
The old one still rattles, has some oil deposit, no idea if it works or not.
Total took 10 minutes, including finding a chair (to reach the PCV), shooting pictures.
Changed this PCV 2 days after the oil change, I will update you if the oil consumption improves in the next oil change (6,000 miles later). Thanks.
doylee4693
Tahoe User
New York
awsome man good to hear, I personally would have paid the extra few dollars for the ac delco brand part just to make sure the part is 100% up to spec so I know that if it still eats oil its due to something internal and not due to a off brand valve jmho. Let us know how it works out!
yukonese
After putting the new PCV in, the oil consumption is still the same, one quart between oil changes. Since there is no any deposit on the ground, the oil must be burned. Any other idea how it gets burned? Do oil additives help? Thanks.
low01denali
San Antonio, TX
Well if you think about it, there's really only two places oil can reach the combustion chamber on the LS engines; besides major damage like a cracked head/block/piston, the oil control rings on the piston and the valve stem seals in the heads. My guess if you have a high mileage engine, it would most likely be the valve stem seals, but worst case scenario the oil rings on the piston could be bad. Judging from service centers saying this amount of oil consumption on the higher mileage engines being normal would point me to the valve stem seals since they are a softer material opposed to the metal oil control rings. My common sense would say metal would last longer than plastic/rubber. And that is a DIY project for any serious home mechanic. If you choose to go that route and try replacing the seals, I would also suggest replacing the valve springs as well if you're high mileage since you have to remove them anyways to replace the seals. They tend to loose their full potential around 100k-150k
03z71chevy
Buford, GA
Mine was burning a few quarts between oil changes and I changed the PCV valve as well with no effect. I do have 236K on the clock but only 60K since a rebuild and it has always run royal purple. I did switch to 10w30 the last oil change and that seems to have made a big difference. May go up to 10w40 the next oil change.
yukonese
5w30 to 10w30
My 01 Yukon has only 80k miles now, far from high mileage. I noticed this oil consumption since 50k. I used to use 10w30, then changed to 5w30, but forgot since when. I'll try go back to 10w30 next time. Thanks.
FreshLikeOprah
Not a common issue? Really? Ive been in the LS Engine game awhile, and yes, actually it is a common thing. Most of these Gen III/IV engines burn a lil oil. Put a catch can on it, or go with a LS6 valley cover. Should help some of the issue.
Also, I dont believe is spending all that money on high dollar oils. Ive got quite a few very high mile engines in my family, all ran on standard 10w30 Castrol, or 15w40 Rotella. I keep them changed at every 3k, and have never had a issue, and Im ******* my vehicles.
03z71chevy
Buford, GA
I kind of agree with you about the expensive oils. This is actually the first vehicle I have ever had that I used synthetic oil in. The reason being is I purchased my Tahoe used from a very particular person who had always put Royal Purple in it and I just decided to keep it that way. At over $8 a quart it just makes this oil burning crap that much worse though.
Z15
Michigan ,USA
Fyi
Note - Just about every oem has a bulletin about the same subject.
Subject: Information on Engine Oil Consumption Guidelines
Models: 2009 and Prior GM Passenger Cars and Gasoline-Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)
This bulletin is being revised to update the warranty information on vehicles and add model years. Please discard Corporate Bulletin Number 01-06-01-011E (Section 06 -- Engine/Propulsion System).
All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the power stroke, part of this oil layer is consumed in the combustion process. As a result, varying rates of oil consumption are accepted as normal in all engines.
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
Important: This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or driven at legal speeds in an unloaded (for trucks) condition.
Important: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more.
Many factors can affect a customer's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption.
Gasket and External Leaks
Inspect the oil pan and engine covers for leakage due to over-tightened, damaged, or out of place gaskets. Inspect oil lines and fittings for signs of leakage.
Improper Reading of the Oil Level Indicator (Dipstick)
Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked.
Notice: Operating your vehicle with an oil level that is below the minimum level indicated on the engine oil dipstick can result in severe engine damage. Repairs resulting from operating an engine with insufficient oil are not covered under the terms of the New Vehicle Warranty.
Important: Refer to Owner Manual in SI for checking and adding engine oil.
Not Waiting Long Enough After Running Engine to Check Oil Level
Some engines require more time than others for the oil to drain back into the crankcase. To assure a sufficient amount of oil has drained back to the crankcase, and an accurate reading can be obtained, the vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked.
Important: This does not apply to 2006-2009 Corvette Z06 equipped with the 7.0L LS7 and the 2009 Corvette ZR-1 with the 6.2L LS9 engines (dry sump). Follow the instructions in the Owner Manual for checking the oil in this application.
Improper Oil Fill after an Oil Change
Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner Manual or Service Manual for information on recommended oil quantity, viscosity, and quality.
Aggressive Driving, High Speed or High RPM Driving
Aggressive driving and/or continuous driving at high speeds/high RPMs will increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected.
A higher rate of oil consumption is normal for vehicles equipped with manual transmissions that are driven aggressively. By "aggressive," we mean operation at high RPM (3,000 RPM to redline), with frequent use of engine braking (using the engine to slow the vehicle). Vehicles that are driven aggressively may consume engine oil at a rate of up to 0.946 L (1 quart) every 805 km (500 mi). This is normal for a vehicle that is driven aggressively. No repair is necessary. This characteristic does, however, require the owner to check the engine oil level at sufficiently frequent intervals, especially when driving aggressively, to assure the oil level remains within the recommended operating range. As the Owner’s Manual recommends, you should check the oil level every time you get fuel.
Towing or Heavy Usage
Towing a trailer will increase oil consumption and may cause oil consumption to fall below the normal accepted rate referenced in this bulletin for an unloaded vehicle in a personal use application. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption.
Crankcase Ventilation System
Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use.
Oil Dilution (Fuel and Water)
On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, unburned fuel and condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture and fuel, may give the customer the impression of excessive oil consumption.
Engine Temperature
If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order.
Engine Wear
Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption.
Measurement of Oil Consumption
Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).
Verify that the engine has no external leaks. Repair as necessary.
Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual).
Park the vehicle on a level surface.
Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that the oil has had time to drain back into the crankcase.
Verify that the oil level is at, but not above, the full mark on the dipstick, and that the proper viscosity and quality oil are being used as recommended in the Owner's Manual.
Record the vehicle mileage, date, and exact oil level on the form included in this bulletin.
Ask the customer to verify the oil level, each time the vehicle is fueled, following steps 1-6 and return the vehicle to the dealership if the oil level is found at or below the add mark, 0.946 liter (1 qt) low. If the oil level remains above the add mark, the customer should continue to operate the vehicle and verify the engine oil level until 3200 km (2000 mi) has accumulated before returning to the dealership for a final evaluation.
If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 3200 km (2000 mi), follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 3200 km (2000 mi), explain to the customer that their engine meets the guidelines for oil consumption.
R3FAN1
Burning oil produces a light blue/white smoke. A rich fuel mixture produces dark/black smoke
johnsonwillie199
