07Burb’s 2013 LTZ Burb Thread
91RS
GA
I sure hope you got a good 17. There’s no way I would have gotten rid of a super low mile 900 for a K2.
Administrator
If it hasn't had the updated trans fluid, get that done and you should be good to go
Fill me in on this. How can I tell if it has or not and what is the difference between the updated and non-updated trans fluid?
pwtr02ss
Tennessee
I'm not sure how to visibly tell, although if it does, it should have been performed at the dealer so you could request service records from your local dealer. If it hasn't been done, you may see transmission shutter and things in hot weather. The "new" Mobil 1 fluid solves this. The issue with the old fluid is basically the design of the trans cooler. Apparently it runs through the ac condenser and cools it rapidly. This creates condensation. The new fluid is designed to get rid of the excess water better. I read a ton about this problems a long time ago. I was ready to pull the trigger in 2015 for a k2, then to 2015.5 thing happened and I thought that was crappy of gm. Then the 8 speed issues (see revised fluid statement), then finally in 18, they switched to 10 speed and I saw very little complaints. Finally bought my 19 at the end of 2018
randeez
south florida
the fluid they put in them till late 2018(? i think) attracted water, and the trans temp stays so low that it wouldnt ever burn away. ctsv would shudder a little if you were like coasting at 50mph or so and lightly get back into throttle. got progressively worse. dealer ended up changing converter and fluid to fix. been good since. not sure if they updated trans tune too but it seemed to shift 100x better
me, you, and @Rocket Man needs to start red only thread
Administrator
Cool. Thanks for the info. I may just play it safe and have the trans serviced and request the Mobile1 fluid.
The red/maroon is a definitely a good color especially when clean.
Administrator
Welp, she’s headed on to their feller’s home. It was decided to ship her because finding the time to come get her and drive her to her new home was not feasible. With any luck, tho, we’ll be seeing her on TYF again in the future #happytrails #shesagoodone #youwillbemissed
zkonrad001
