07 ltz 4x4 traction control left front tire brakes till light comes on
Clarko88
So after I did motor mounts.. first drive of the day I drive 20 feet and the traction control activates brakes the left front tire then light comes on and I cant drive like normal
C
Clarko88
Also I replaced that wheel hub trying to fix the issue with no luck. I should mention i did install the steering wheel upside down.. and noticed when I got to work.... I fixed it and still the light comes on.... stabilitrak message pops up too.
mikez71
Did you remove the steering shaft? If you put it on rotated from where it was, the steering angle could be off, or sensor damaged..
Try unplugging the steering angle sensor near the pedals on the steering column.
With a decent scanner, you can check the steering angle sensor reading... and what codes are causing the stabilitrac light to be on.
mikez71
If your sensor isn't broken, you will need a scanner to know which direction to rotate the shaft..
Unplugging the sensor should disable any weird behavior in the meantime.
a1parrothead
