I wish I did! Instead I ordered an amazon part, its loose to valve cover.. If i press on it, it leaks!
$15 seemed better than $47 OEM.. (But $0 would have been better...)
Don't buy the YCUPONE brand.. Hard to complain too much for $20 delivered this morning, ordered last night..
Me pressing on it lightly making it leak.. Normally it sits pretty square, but there just isn't much tension on the o-ring..
It seemed impossible to use a pick to undo the locking tab, it has to make it around the bend, and my pick was too short..
Removed old one, the tab didn't break initially, but the whole bottom part did!
Luckily I could fish it out with needle nose.. All bits accounted for.
Now my right rear window went down and clunked, won't go up anymore..
Rear heater does not work.. AC works.. Will have to check hoses to see if they are looped in back..
Little worried my tailpipe still has water after idling for a long time.. Drove around the block and finally tailpipe is dry, but coolant level dropped 1"..
Hoping it was just an incomplete bleed, otherwise I may have bigger issues..
ECT good and steady at 194 and oil pressure good at ~35psi hot idle..
Watched misfire counter and only ever saw 1 blipping throttle several times..
Hooked up my tech 2, but some reason fuel trim and chime pages don't load, but I can see fuel trims and they're 1-3% for all..
Well time to pull the rear door panel, I hope I don't need some more plastic parts to fix the window..
