6speedblazer
It works. See link below. I put the arms from an earlier Suburban on mine. Pick n Pull FTW.
Heck yeah! I wasnt sure if it would work or not. But for 8 dollars for two pairs of arms, i was going to try and figure it out.
mikez71
Installed Spectra radiator and dorman hoses and t's, and delco radiator hoses. Stupid cooler line clips were too tight on radiator. Muscled the trans lines in, but oil cooler ports needed original clips. I would have paid more to avoid that frustration. Why are they called quick-connects when they always take longer than the old hose clamp?! Hopefully radiator doesn't leak as hard as I was shoving on it. Also the little plastic washer cover was hard to fit over the Spectra clips. If you go Spectra, use all your original clips! Original on right side.
Heater T's were a struggle, cut the retainer tabs as @Doubeleive suggests, and luckily the T disconnects from heater core since that would be really hard to reach with any cutters I have..
Had to insert wires and conduit into main conduit bundle. As they were, the edge of conduit could wear through wire insulation.
Coolant tank just arrived, going to install and fire it up soon..
mikez71
Well it's running again...
But noticed this.. I can't seem to square it up..
I don't feel like doing valve covers just yet.. If I twist it off, how much does a broken plastic tab matter? (inside the head)
I saw a video where someone used a 90deg pick to pry up on the plastic retainer tab.. Not confident I will succeed with that..
Also saw a video where the guy put the cap right on valve cover and it fits perfectly..
ScottyBoy
Shreveport, La
Had to jump start my Suburban to move it to cut the grass around it. The poor old girl is just sitting out there getting weathered now that I don't drive her anymore. My wife says I should just sell it, but I just can't bring myself to get rid of a perfectly good vehicle (does need a battery now though). I don't drive it anymore because I have a company vehicle that's my daily driver now.
mikez71
That's like the Suburban I just bought.. been sitting.. They threw a new small battery in..
I'd prefer a top post battery.. But that means new cables becauses I don't want an adapter.. but maybe I'll just get an adapter temporarily..
And I don't know how much I'll actually drive this thing, but I just needed a new money-pit/time-pit I guess...
TheAutumnWind
Can confirm that filler neck and the cap have the same thread. You can just screw the cap into the valve cover without the neck.
mikez71
I wish I did! Instead I ordered an amazon part, its loose to valve cover.. If i press on it, it leaks!
$15 seemed better than $47 OEM.. (But $0 would have been better...)
Don't buy the YCUPONE brand.. Hard to complain too much for $20 delivered this morning, ordered last night..
Me pressing on it lightly making it leak.. Normally it sits pretty square, but there just isn't much tension on the o-ring..
It seemed impossible to use a pick to undo the locking tab, it has to make it around the bend, and my pick was too short..
Removed old one, the tab didn't break initially, but the whole bottom part did!
Luckily I could fish it out with needle nose.. All bits accounted for.
Now my right rear window went down and clunked, won't go up anymore..
Rear heater does not work.. AC works.. Will have to check hoses to see if they are looped in back..
Little worried my tailpipe still has water after idling for a long time.. Drove around the block and finally tailpipe is dry, but coolant level dropped 1"..
Hoping it was just an incomplete bleed, otherwise I may have bigger issues..
ECT good and steady at 194 and oil pressure good at ~35psi hot idle..
Watched misfire counter and only ever saw 1 blipping throttle several times..
Hooked up my tech 2, but some reason fuel trim and chime pages don't load, but I can see fuel trims and they're 1-3% for all..
Well time to pull the rear door panel, I hope I don't need some more plastic parts to fix the window..
mikez71
Found these codes so far.. Nothing powertrain related I could find..
I know my cluster dimming is weird and dome off switch does not work..
Hoping a new switch will fix it, but maybe it's my cluster.. (My speedo moved a tiny bit as I was revving in park)
Maybe this is rear heat issue?
Pedals do work, but I guess position circuit bad..
mikez71
At least the price is reasonable, so I'll order a new regulator unit.
Open to tips/suggestions on replacement, OEM isn't available for the rears...
What's more concerning to me, when I open the reservoir cap, there's pressure or vacuum.. (will verify soon)
If vacuum, I'm hoping it's from an incomplete bleed or faulty cap..
If pressure, what else but a blown HG would do it? I'm scared...
Don't sell it, you'll definitely regret it.
Try swapping the oem O rings to the cheap part. Might be that's all it'll need to fix it.
I get my parts from Amazon, but before I order I ALWAYS check the reviews 1st. I skip over the parts that have less then 50 reviews.
mikez71
Yea there weren't too many reviews, but it seemed like all the bad ones were people who purchased for the wrong vehicle..
$47 bucks for an OEM plastic tube.. It just felt wrong.
And I didn't want to wait 2 days for the Dorman.. which doesn't show an O-ring in the photo!
I would swap O-rings, but I don't know how to get it off without breaking it or doing valve covers..
When I do finally get to it, I'll probably just delete the tube becase I'm pissed at it right now!
clandr1
Dallas/Fort Worth, Texas
Here’s an OEM for $33
mikez71
Thanks! Dangit I should know better than to not get OEM, but more and more parts aren't available anymore except for amazon!
Does anyone know if aftermarket light switches are any good? I might buy a stock one.. Like I bought some used AC vents, but the interior foam is all deteriorated.. Wonder if I should have just gotten new repops...
Electrickian
Senior Member
Got the broken junkyard bezel fixed. Plastic welded 4 broken spots at the top edge, and attached 4 missing clips. Plastic welded those on too. I sanded rough spots down, then used plastic adhesion promoter, then sprayed with charcoal grey interior trim paint. What do you think?
Looks good to me. What plastic weld did you use?
6speedblazer
Dont forget the plastic fittings for the rear heater core. Mine that were under the truck were soft and the aluminum crimp collar was split from corrosion.
Dorman 800-419HP is the fitting for the rear. 3/4" quick connect to 5/8" hose barb, 90* fitting.
strutaeng
Dallas, Texas
Just start it and let it come up to operating temperature every 2 weeks.. That will keep the battery charged, burn off moisture and help keep the rubber hoses and belts from becoming brittle from sitting.
mikez71
Ok, what's the trick to getting the right driver side vent out? Mine has a couple broken flaps, but it looks like the dash needs to come out to get to that screw?
Also thinking about new material to replace foam seal for vent flaps.. Not sure if i should use thin rubber (might whistle when closed?) or just leave it alone since they're usually all open anyway.. Another plate sandwiches the old foam, which extends around the outside edges.
jkhuntzinger
