89Suburban
Bull in the china shop
SE PA
Kind of curious, @89Suburban why you had to cut the nylon lines. I take it you weren't able to remove the metal pump lines from the (not-so-quick) connectors?
Because they were rusted into oblivion.
I love you guys too much, I have to show you how I attacked this out of mutual respect. Not proud of it but doing what I have to do. :(
I mean, I am proud, but not in the eyes of the word as it is today. :(
I used a Sawzall and drill bits to keep sparks from flying. :(
And the tie wire is strictly to keep the lines from blowing off the non barbed connections. :(
View attachment 360825View attachment 360826View attachment 360827View attachment 360828View attachment 360829
Please get this fixed properly ASAP!
3.4 Bar is less than 50 psi. I know there's a safety margin for the hose rating, but it's still risky as the fuel system operates around and above 50. You deserve to go out in a better way than being roasted in an old Tahoe.
alpha_omega
Michigan
Sorry to say that they're fuel pump lines, not evap.
Even worse…
@89Suburban
Aha! See…your problem is all that rust. You just have to scrub that stuff out of there an viola! Shouldn’t take more than a couple of minutes, then they will come apart…after lots of cursing, a drill bit and sawzall blade.
I’m glad you were able to get a temp fix done. Damn rust belt!
randeez
south florida
damn why'd yall let him do that shit. surely we couldve come up with a better way
at this point i would look into trying to find those quick disconnect fittings looks like 3/8? that hard plastic hose if you put just a little (little heat slowly like heat gun on low - NOT A TORCH) heat into it it will go over a hose barb i would still put a hose clamp on it though.
jmart157
