blizz
San Antonio, TX
With the new wheels and round off-road led lights. The pervious ones were stainless procomps.
Dneel81
OKC
interesting square bill blocking your licence plate.
great looking 2 door by the way.
blizz
San Antonio, TX
Thanks! Yeah it's a lure turned key chain from academy. Now I'm thinking of possibly getting a black grille and doing bed liner under the molding on the sides from fender flare to flare. Hmmmm
Dneel81
OKC
Wish I could trade you. I have the sport model and don't like the blacked out everything. Chrome stuff is expensive
jerryjoe28
That Guy
cabot AR
if you do the bedlinner, why not just pull the molding off and fallow the body line?
Dneel81
OKC
Make darn sure you're not dealing with rust under the door panels anywhere. Only if that's pefect can/should you bedliner it. If you ever have to take it off, it's awful.
jerryjoe28
That Guy
cabot AR
yeah u always want to make sure surface prep is done before doing any type of coating. as for the removal I found media blasting is about your only option!
domer94
northwest NJ
just sold my 96 2 door with 193k for $5200. part of me hated to see it go , but im venturing into an 08 wrangler sahara unlimited. still have the wifes 99 burb to mess with! I put the wheels / tires from my 2 door on the burb today and man does she look badass. I love the stance
by the way , how are rancho shocks, are they a good combo for the suburban?
noJeepshere
Bountyfull, Utahrd
Burb looks good. As for Rancho shocks, I ran them on mine before my axle swap and honestly think you can find better ones pretty easily. The rear shocks were pretty much spot on for their damping qualities, but the fronts sucked. Bilsteins aren't much more expensive but are much better shocks. And a lot of guys like to get shocks for a 3/4 ton truck for the front, they're stiffer.
sent from a slablet
Beechwood
Michigan
Installed R1 concepts drilled/slotted rotors and ceramic pads, new rear drums and shoes and all hardware, Finally NO MORE MUSHY PEDAL!! Bilstein shocks all around, awaiting new LED tailights. 189,000 miles on the '99 Thinking it will be the last big project , before I move in to an '08 or newer Tahoe in a year or two.
95escahoe
Installed R1 concepts drilled/slotted rotors and ceramic pads, new rear drums and shoes and all hardware, Finally NO MORE MUSHY PEDAL!! Bilstein shocks all around, awaiting new LED tailights. 189,000 miles on the '99 Thinking it will be the last big project , before I move in to an '08 or newer Tahoe in a year or two. View attachment 61330 ,
What style led tails?
Drewphil
