Interior storage
Reaper74
Do you have any pics on how you built the custom sub enclosure im in the middle of building one for two twelves and i have a slight idea but im kinda stumped considering ive never glassed b4
Sent from my LGLS751 using Tapatalk
DallasTahoe
DallasTahoe
Yea I actually have some pics in my photobucket, or you can check my other post from when I built it the pictures are in there. I glassed the back so I could use as much of that airspace as possible. Glassing is actually pretty easy, just need the resin, a staple gun, the wood frame, and a roll of fleece. But Glassing into the quarter panel was pretty hard, trying to get it to stay in the place I wanted it without it falling was tricky
Reaper74
Oh ok so you used fleece instead of fiberglass mat ?
DallasTahoe
DallasTahoe
Yea it's easier to use and it's thicker so you won't have to use so many layers
Reaper74
Cool and it sounds pretty good?
DallasTahoe
DallasTahoe
Yea I filled it with stuffing from an old pillow, it's sounds really good inside, it's not real loud outside, but I don't care about what anyone else outside of my truck can hear. I actually thought about taking one of the subs out to give it more airspace, or just redoing the box completely
Reaper74
Ya thats all that matters it looks freakin awesome to !
GM iraqi
Very nice work especially the case attached to the barn door
Big like bratha
DallasTahoe
DallasTahoe
Big like bratha
Thanks but I took the storage case off of the door, just didn't feel right or look right for some reason
BigRic925
Hey I'm digging the floor. Do you happen to have a write up on that install or measurements perhaps.? Thanks
DallasTahoe
DallasTahoe
No I don’t, I’ve since taken it out, I really just cut the factory carpet and used it for the template, glued the pieces together and cut it just a lil bit big to make sure I didn’t miss any spots. I miss the wood floor but it was really heavy
SVYUKON
How did your spare tire arrangement hold up? Any shifting or rubbing noise?
My99Yukon
I love the wood floor. I will probably replace my carpet for that at some point. But to the discussion about the spare, it is a pretty inexpensive option to find a welder to put together a swingout. I am super happpy with mine. I need to redo my interior setup but it works for now so that is a later project.
SVYUKON
I am just getting into this Yukon and would like to mount my spare internally. I don't carry large loads or in fact even use the back seat with any regularity. So the loss of cargo space would not be an issue. My Excursions used to carry the tire internally. Anyone make an internal mount for the Tahoe/Yukon?
DallasTahoe
DallasTahoe
The tire arrangement was only temporary until I got rid of those massive wheels and tires. Now I have a stock steel spare and it’s back underneath
My99Yukon
Hey Dallas, I am a little bummed to hear you went back to stock steel spare underneath. does that mean you also went back to stock all the way around? I am long over due for an overhaul of my platform but I just cant find the space to get a welding unit and design it to start a new project. perhaps that will come in the summer.
DallasTahoe
DallasTahoe
Why would you be bummed, it was in the way and that wheel was way crusty and the tire was no good. No I got some new pro comps with new tires for $500 so I had to jump on it
AdrienR
