Easy 4-Hi mod - Simple All High Chip 03-06 model years
jdpber
GOLD MEMBER
The America
Ok so some people have done the all high mod and i personal had had it for a while but i was not happy with the jumper wires. I saw this product by Fleece, and knowing the quality of they products that they produce in addition to this being $20.95 I pulled the trigger on Thursday..
Grand total of $24.80 shipped and arrived last night (Monday)
I figured i would be the Ginny pig for anyone looking for a clean and straight forward upgrade.
This mod will take a <5 minutes. I took 10 minutes total and that was sautering and taking pictures once complete.
http://fleeceperformance.com/electronics/gm-all-lights-on/gm-all-lights-on-module.html
This is how the install goes:
Pop the hood
Remove the lid to the fuse box (drivers side at the fender well, this is a black SQUARE BOX)
Now you will want to remove (PULL UP) these indicated 4 relays.
with them removed your box should look like this
If you want to have the ground SIGNAL spade for signal to a Relay for auxiliary lights you will need to sauder this spade tot he board. If yo do not need this then skip this step.
after the board has cooled place it in the fuse box as shown.
With the board installed start to replace the relays (they do not matter the location as they are all the same.
Replace the cover onto the fuse box and shut the hood of the car. Crank her up up and reap your rewards.
NathanJax
Vacation Nathan
Jax, Fl
Awesome!!!
Fosscore
That is sweet! Thx for the write up and info.
I'm running jumpers for this mod but it's a 6 low mod as well as an 8 high (fogs and full time DRL's on low and everything on high) and see this board covers the DRL and fog relay areas. Do you know if they make a board for those mods too?
Fosscore
Any updates on how this board is performing since you installed it a few days ago?
I researched Fleece's website and can only find this single board which turns on the fogs and lows when the high beam is activated. It's a great idea, too bad they don't offer options. I forgot how I did my drl mod- they act normal until the headlights are turned on, then they come on whether I'm in drive or not. And the fogs come on anytime the headlights are on. Then there's my 4 hi mod which is actually now an 8 high. And I deleted the auto headlight function since it caused problems with my HID ballasts. It would sure be nice to have control over all these functions from the DIC.
cmc76
i would like to pick this up as well, but have one question. when I leave my lights set to "auto" during daytime driving will all lights be on? or still just the DRL until the lights come on themselves?
David Paul
Central NJ
Just installed this. Easiest mod ever. Very professional looking, OEM look. If you look closely, there are no contacts for the DRL lights on the board so I assume there will be no affect on them. Too dark already here, lights come on automaticly. This arrived very quickly....impressed.
jdpber
jdpber
GOLD MEMBER
The America
In the day time only the daytime lower center lights are on. When the dash sensor switches your gauge lights on and low beams on plus drive. Then click high and your high, low, drive, and fog are on.
BADRIDES
Will this work on an 02 model? it says for 2003-2007 models.
jdpber
jdpber
GOLD MEMBER
The America
I cannot answer this for sure. But in 03 they made a lot of BCM changes and i think that this is the reasoning for the '03+ statement.
but you can take a $20 gamble and inform the rest of us
Mr. 960
I noticed you have to remove the day time running light relay. Does this make the daytime running lamps light up with he high beams? I DON"T want my day time running lights on, just the low's, high's and fog's
05Single
afraid of the dark
Only works on 03-07. The fuse boxs are a different set up. Its the first of its kind so I bet they're designing right now for other models.
im gonna order me one. Its $25 but its a clean install.
Worth it to me than a $3 ghetto looking wire jumper. Piece of mind
BADRIDES
I e-mailed the company and they have NO plans on making this part for the 99-02 model trucks and Tahoe's.
Durobans
