DallasTahoe
Got my subs put in today, cut my bumper and fenders so I don't cut up my 33's while running no lift, and tomorrow I'll put in my Big 4 setup and start thinking about adding my 2nd battery
Dneel81
OKC
finished the rear shackle flip and started the front end rebuild. Bushings in all control arms, ball joints, and shocks. What a PITA. Curse the engineer who thought rivets were a good idea on the upper ball joint...
chaingun427
OBS Mad Scientist
Mooreland, OK
Installed the projector mods, still need to make som adjustments but the homemade recess for the phantom grill turned out pretty good
Sent from my SAMSUNG-SM-N920A using Tapatalk
Gzes
the drifting 2dr
Wichita tx
Need a new battery now that it's been sitting.. looks like I'm getting an iron camaro for the motor to put in while I find a cummins swap
Johnny Racer
Chicago, IL
Replaced failing/worn distributor - P1345 code
Replaced spark nuggets and wires
Replaced fuel filter
Cleaned air filter
Replaced both down stream O2 sensors
Replaced broken sway bar
Replaced both front lower control arms
Replaced all 4 shocks
Replaced rear brake shoes and drums
Replaced blower motor
Replaced rear barn door lock actuator
Replaced rear tail lamp assemblies
Replaced Drivers Front outer door handle
Changed oil and filter
And that's about it. LOL
Frankenstein95
Pushed out the girlfriends brothers 400, with the Yukon, because he got stuck in the snow I the front yard. Ha ha
chaingun427
OBS Mad Scientist
Mooreland, OK
Found out my ls swap has a dead cylinder. Ordering new rings, hone, etc
chaingun427
OBS Mad Scientist
Mooreland, OK
60lbs compression on #6 visible shaking of an internally balanced motor led to a compresion test, pulled the head after a leak down test and found this
head gaskets were starting to rot too so they needed changed anyways
Big Poppa Pump
Brunswick Maryland
Completed my front hub replacement a few days ago. I used Timken hubs. It did not go easy. My bolts were so bad they needed the bolt heads chiseled off and then extracted due to rust deterioration of the bolt head. Only 2 of the total of six (Did both sides) came out clean. I had to pay to get it up on a lift because it was too involved for jack stands. I also had to pay $13 a bolt because I did not have them on hand and had to pay to have them delivered. The good news is that it fixed the problems I was having with wheel movement and the ABS sensor activating when driving low speeds. Now my truck is back to being dependable. I was going to go ahead and change my front oxygen sensors while I was at it but the rust is so bad I had to stop or risk twisting the whole bung out of the exhaust pipe. I guess 173,000 miles of road salt will complicate things. I wish I would have washed the truck more often.
chaingun427
OBS Mad Scientist
Mooreland, OK
nasty. and a bummer. ringing the whole block or just that one? i seem to notice it appears you also have the wrong coolant in there.
Going to do the whole thing, no reason to half ass it twice. I should have comoression tested on the stand so now its biting me in the ass. I'm not sure if thats rust or left over dexcrap, haven't run it long enough to flush it yet
chaingun427
OBS Mad Scientist
Mooreland, OK
It had 2 gallons of fresh mix with anything coolant, never been fond of dexcool
Dneel81
OKC
FInally got my rear end done (shackle flip and new shocks, ubolt flip kit) and the front end (pitman and idler arms, all ball joints, upper and lower control arm bushings, sway bar bushings and link arms and shocks. CV drive shaft comes in tonight and I should be back on the road after an alignment.
Dneel81
OKC
measured new and old tie rods and they're close enough to get me down back country oklahoma roads to the alignment shop. I'll wear my seatbelt and go early in the morning so when it falls apart because I forgot to tighten something, I won't hurt anyone else.
Drewphil
