Confused about lowering
popo8
popo8
Ok. Soon as i have it
LTXtech.com IS my drug...
popo8
popo8
Ok... 1st thing that needs to be addressed
NORCAL SS
SUV SUSPENSION GURU
Ask them if they
1. Took off the rear sensor lines on outside of frame whwn they dropped rear end to put springs in. If y
Nit could of snapped a line
2. In rear how did they adjust the autoride links. I've seen shops adjust them on the truck and break the sensor
3. In front make sure the autoride connections are on. If they forgot to put it or or forced thrm.on from a angle could have damaged them.
I'd just take it back have thrm check it out becuase somethings not right.
popo8
popo8
I took a screen shot of ur post and sent it to them. Its aft hours now so may not hear till 2moro. Other than the light it def rides tighter. Have not bottomed out yet.
I have not heard the comprrssor at all either. Im guessing maybe the switch/sensor may not have been modified....
NORCAL SS
SUV SUSPENSION GURU
Its prob not coming on because somethings messed up. If they didnt move the rear autoride links then the compressor would kick on all the time. Im sure they will fix whatever it is. What kit did they use on it?
popo8
popo8
Belltech
---------- Post added at 08:32 PM ---------- Previous post was at 08:31 PM ----------
Oh they will def make it right, i just want that light to stop staring at me, lol
NORCAL SS
SUV SUSPENSION GURU
Wait why did they use nitro shocks??? That kills the autoride.
They bypassed your autoride that's why you have the sign on dash since they got rid of all shocks. Was your autoride working fine before??? Did you want to keep autoride?
popo8
popo8
I did want to keep the aito ride. Nothing is removed. Its all still there tho?
NORCAL SS
SUV SUSPENSION GURU
On their page they said "nitro drop shocks" which are replacements. They sell the nitro 2 and the belltech sp which sp is much better.
If you have the truck with you check to see if the rear shocks are new. They said nitro shocks so im guessing they took your autoride shocks out.
popo8
popo8
At least I thought so. I will get under it in the am and take a look.
---------- Post added at 12:28 AM ---------- Previous post was at 12:26 AM ----------
Ok, good info. Its out in the dark now. 0026hrs here in PA. ILL take a look first thing in the am.
I did screen shot ur post and send it to the owner of the business now. I let him know if thats the case, this needs to be reversed.
Or in ur opinion is it ok without it?
What am I losing by replacing the auto ride with the nitros?
---------- Post added at 12:59 AM ---------- Previous post was at 12:28 AM ----------
I guess what Im asking... am I really losing anything by not having the air ride? I guess i was stuck on keeping it, cause its part of what makes it the caddy and not NOT a caddy.
If the nitros replaced it, technically i can remove the compressor amd stuff now right?
Guess it also means I coulda gone with more drop? Lol.
Is there a way to kill the light (i guess i only need to worry about this if ur answers to the previous are not negative or detrimental to the ride or safety.
Fyi... i launched it over some rail road tracks and do think i bottomed out... but it def took aggressive drivinh for me to do it. Lol
NORCAL SS
SUV SUSPENSION GURU
Pull battery leads and pull rtd fuse sit for few then you can hook it back and light should be off.
popo8
popo8
Wow... thanku man!
Btw, do u feel im giving anything up by losing the air leveler for the nitro shocks
---------- Post added at 08:07 AM ---------- Previous post was at 07:49 AM ----------
I just got word. Air stuff is not deleted. Nitros are in the front. Air stuff is in the rear. Its an 02 if that makes a difference.
NORCAL SS
SUV SUSPENSION GURU
If obo new you were ok with getting rid of autoride I would of done my 3/5 kitz
popo8
popo8
Well im talkin to him to do the free travel mod for me when i drop it back off.
Air ride is still there. Nitro shocks were just front replacemnts
---------- Post added at 08:58 AM ---------- Previous post was at 08:57 AM ----------
So its still good... is there info on how to adjust the switch for the air ride
NORCAL SS
SUV SUSPENSION GURU
Why did he change the front shocks?? Just curious because if you were going to keep rear autoride I'd keep oem fronts on. Many times due to pulling front shocks Rear system will not work correctly. Also now that you pull rtd fuse the air system won't work rught but light will turn off. I'd put oem frint shocks back in and be done with it.
Have they done a lot of these trucks? They should have put resistors in to bypass front kit and will keep rear working and will keep light off
popo8
popo8
I didnt pull it yet.
Replaced cause 120k miles
---------- Post added at 10:16 AM ---------- Previous post was at 10:16 AM ----------
So now what ur saying is there is a switch up front for the rear air ride as well!
NORCAL SS
SUV SUSPENSION GURU
How many of these trucks has the shop done? Did they tell you about lights before lowering it? Sorry just upsets me because I hear this a lot then the shops call me asking how to fix it.... I don't understand why shops take on jobs when they don't know what they are doing...
Sorry had to vent but yes what they did will disable the entire system. It's a fault now so u less they put oem shocks backnin or cut wire harness and put in resistor light will stay on and back won't work......or you can remove air rear set up but use belltech sp shocks not any of the nitros. They are not as good at all and I don't touch em.
popo8
popo8
Idk how many they have done. I have no problem with the learning curve. No need to be upset about it. They do lots of work for me to all my vehicles. They never leave me hang if there is an issue. Just need to make it rightm
---------- Post added at 10:45 AM ---------- Previous post was at 10:44 AM ----------
Im sure there was a time EVERY shop, including u... did ur FIRST anything and a learning curve with questiins and mistakes were a part of it.
NORCAL SS
SUV SUSPENSION GURU
On autoride suv back in 99 when I did my first 00 I did free install and learned all I could. Just like in any new trucks or suvs or cars I do o don't charge on first install because if something goes wrong don't want customer to be like wtf man.
But anyways back to your truck.
You can do either of these
1. Have them put front oem shocks back in
2. In rear take out stock shocks and replace with belltech sp and pull rtd fuse
3. Splice in resistors on front so system still thinks oem shocks are back in.
popo8
popo8
Looks like there were supposed to be shorter "level ride control rods" that did not come with the kit...
CrackerJack135
