- Joined
- Jan 3, 2011
- Posts
- 50,986
- Reaction score
- 19,537
Yeah... im usually quick to pop. Its my curse I guess.
Ok.. thanku.No not saying that just want to see the swaybar angle. There's a reason I recommened the rear swayear links just wanted to see yours after lowering to see how far it is.
Whenever I set up a kit I like to set it up complete that's all. And theres been many times herr people bought kits and ended up saying resr felt funny and did links and bumpstops and they were a lot happier with ride.
Your happy with the kit great thats all that matters but for someone that is into kits on these trucks I like to gather any info I can. Sorry for all the question
Btw with almost 4 inches in rear won't be much travel if it feels bumpy will need to do free travel mod. Anyone here can agree on that
I can only hopeIf it has almost 4 inch drop and rides better thats even better
Btw... Sorry about going off on u earlier. Maybe I was reading into stuff 2 much.
LTXtech.com IS my drug...
1st part let me say... ur right and i didnt edit my skits so that the appology makes sense. I owed him that. I WAS WRONG.Reading thru the post it does sound like you popped a gasket but coming from someone who has no dog in this fight... If your truck hasnt had the free travel mod done to it yet and your sitting at a 4" drop your ass end is going to bottom out and ride like total crap. i highly recommend you take tonys advice as the dude knows his stuff and according to your own admission you know very little about drop kits and such
What is the best drop for me with 305 / 30 / 26 tires all the way around. What kit will work best 2/3 or 2/4 thanks
Do u have the link to the free travel mod instructions?Hey Tony I did the free travel mod today but I don't see how to install the bumpstops- there's no way to get to the nuts. Do you just drill and tap a hole in the frame and use vise grips to tighten the bumpstop ? I made some 2 1/2" Autoride ride links and it sits almost perfectly level now. I'm concerned that if it's loaded or towing a heavy trailer it might hit without those stops installed. Now if those endlinks get here...looking good though.
unbolt the lower trailing arm where it meets the axle and pivot out of the way you will be able to bolt the bump stop to the axle pad there should be a hole towards the rear section of the pad, its tight to get the nut up in there but you can do it...getting the trailing arm out of the way was necessary for me to get my fingers up in the hole to hold the nut ( no wise crackin jokes please... Lol) you might try to hold it with some needle nose pliers...
That looks sick!
---------- Post added at 10:24 PM ---------- Previous post was at 10:24 PM ----------
