Broken Motor Mounts
Martins denali
125,000 miles and broken drivers side mount
Gm this is just sad
My68 camaro still has the recall ( cable tie down) for a bad motor mount
Looks like they could fix this in 48 years or so
Update local dealer wanted 192.00 plus tax
Dealer 2 170.00plus tax
Local shop ( trusted) 125.00 plus tax
All with me suppling mount 125.00 gm
Catch can ordered
rroadkilll
Kodiak Alaska
Changed it out in about 1.5 hours...
So thankful for good friends with MANY tools and a semi warm garage!!!
I'll try and get a video of the old one if anyone is interested!
tripage
Which mounts did you use. I also saw the ones on ebay with 5 year warranty and debating trying them over the 1 year OEM ones.
---------- Post added at 08:32 AM ---------- Previous post was at 08:17 AM ----------
$131 for OEM mount. Service is still closed so trying to see if I am going to tackle this or let them deal with it. So I get the wife's hoe for the day!!
tripage
I went with the OEM one...
Some of the bolts were a pain!
Hopefully you have an extra set of hands...
Did you only do the driver side? I haven't looked at the passenger side yet to see how it's holding up.
rroadkilll
Kodiak Alaska
Yeah... only did the drivers side...
Also cleaned the mass airflow sensor and the throttle body... but that's off topic!
rroadkilll
Kodiak Alaska
I used a 1 by board and jacked on the bolts that hold the oil pan... wasn't a fan of jacking but I knew it had to be done...
I did have to manipulate the heat shield to get the bolts out... and carefully moved it to get the bolts back in...
Jlw8614
I have similar issue. Took 2007 escalade in for oil change and told engine mount is missing and replacement is $500. I also have 2 cracks in dash and they quoted $500. I take awesome care of my escalade and keep conditioner on dash and always is windshield sun screen. Don't get why I continue to have issues like this on such a nice and expensive car. Loosing engine mount is ridiculous.
joshcarl
Woodbine, Ga
$500 for a motor mount??? RockAuto has them for $25-100 each. you should be able to replace them in less than an hour yourself with just a floor jack and a block of wood to lift the motor up after unbolting them.
ezdaar
Chat Troll
Redneck central, Aka Houston
tell that crook, get bent.
Passin Thru
Dutchtown, LA
Just adding to this:
2007 z71 2wd Tahoe
Changed drivers motor mount a few months ago. Started doing it on my own and got to a point where I couldn't break the bolts. Dropped it off at a friend of mine's shop and had then do it. Bought the part from a dealership I get a huge discount at because I wanted a factory part and not 3rd party.
This is ridiculous. Between the cracked dash, front hub bearings, the clunk from the rear, and the driver's engine mount. WTH?
Joshin33
NC
Yup, add me to the list. Less than 68 thousand miles. Thought I was having transmission issues (still not sure that isn't the case) but the dealer tells me the jumping I'm feeling in 1st gear is because the motor mount is broken. Almost $450. What a crock. Tahoe stays garaged, don't tow, etc. Weekend and vacation driver yet the motor mounts can't hold up. Already sent a PM to GM Customer Service. Lets see if they are still helping since this seems to be a continuous issue.
Joshin33
NC
Haven't heard anything back from GM Customer Service. Anyone have a direct contact phone number they have used? Figured I'd check here before I start going through the mounds of automated systems
CKendrick
