chaingun427
OBS Mad Scientist
Mooreland, OK
Hmm where can I get those from? Never had an issue with Felpro myself but that's almost always been stock manifolds too
jerryjoe28
That Guy
cabot AR
Do yourself a favor and get the compressed graphite ones, I originally put fel-pro gaskets when I did my headers and they never sealed properly and totally gave up after 3000 miles. The compressed graphite gaskets are much nicer.
cent frum a smaert fone
yea mine came with graphite gaskets and said DO NOT use anything else
mattss90
Kingsburg, California
ive spent a few hours looking at how to upgrade the towing/weight capacities from 6200 to hopefully the 8000+ range(i know the motor can but not the axle), bigger and better rear axle for towing and maybe looking into getting a 4L80 tranny instead of regearing, putting a shift kit, and a badass tranny cooler on my 4L60.
noJeepshere
Bountyfull, Utahrd
6 lug 14 bolt semi-float axle with 4.10 gears and disc brakes, helper springs or air bags, swap your trans for a 4l70e (the same low gears as the '60e but almost as strong as the '80e) new master cylinder for the discs. That will get you your load capacity.
chaingun427
OBS Mad Scientist
Mooreland, OK
Hydroboost is also a good upgrade if you dont' want to do the disc conversion.
I got the floor cut out of Rollie to reveal this big beautiful bastard
NV4500 and np241
bigal11419
Queens, NY
Still undecided on the sub. Definitely not using the amp and cd changer. Still haven't finalized what I am adding to it.
_Dylan_
STAY FROSTY
Put some wipers on it lol. Might change the oil this weekend.
chaingun427
OBS Mad Scientist
Mooreland, OK
Got the old slushbox out yesterday, and dropped the lower dash and steering column in preparation of cutting some holes! going to be cutting out and installing the clutch master, and tcase shifter tomorrow, and cutting the hole for the manual shifter.
With any luck this weekend I can pull the motor and trans from Rollie and go straight into the hoe with it.
bigal11419
Queens, NY
Ordered all new steering linkage parts, new tail lights, new belt, new idler and tensioner pulleys, and a steering damper. Hopefully I get some nice weather when everything shows up.
95escahoe
Picked up these frame bumper brackets from my buddy today he powder coated them, came out mint
Here they are before
qukon 95
That sub is 1.4 ohms so you will need a class d amp that's STABLE @ 1ohm. I did the mtx class d 350 rms@ 1ohms for mine since there's no power rating on the sub this is plenty of power for sub to me.
I got theLP filter at 100 hz this little sub does the job
:worship
NjA4207
