IMPORTANT: The Chronicles of Low Oil Pressure by 07burb
HoS
Buy a premium oil, cheapest insurance policy!
Additives are snake oil.
Also, if your car owners guide doesn't ask for synthetic, dont run it.
Been using a premium oil since I bought it 5 years ago :waytogo:
Looks like the issue is fixed! The culprit is a screen that sits between the oil sensor and the oil flow. It gets gunked up over time which in turn leads to false readings.
Here's a pic of the screen that was removed
I will update the initial post with this info in case someone searches for it
No, top of the block at the back near the fire wall where the pressure sensor is at. You take the pressure sensor out then that pulls out. Another reason why it's EXTREMELY important to do regular oil changes. Not 100% about how often the previous owner changed the oil prior to us owning it. :shrug:
TheAutumnWind
Excellent! Glad to hear that you have found the issue.
Gtk thanks
:waytogo: this is why forums are so great. Knowledge sharing. I'm sure there are other things that can cause this condition but will hopefully give people a place to start when troubleshooting
08grey
Nice. Did you change it or just delete it?
NathanJax
Vacation Nathan
Jax, Fl
Awesome!
livingez_123
Sandy, OR
My 6.0 has run flawless for the 8 years I have owned. I wonder if its a 6.2 issue. Most Ls based engines are bullet proof unless you own one of them alum block engines.
Drewphil
