95escahoe
Oil change, rotation, and picked up some 17x8 American racing wheels on the Summit Racing discount rack today. One has a slight dent on the lip which I can get fixed through work or just live with it. Any tire suggestions?
If you want a A/T tire the Hankook Dynapro ATM's are great for all year round use, and can't beat the price
99YukonSLT
Ohio
What size though? I'm not familiar with sizing for trucks/suvs. Always been more of a car guy.
95escahoe
Not to sure it was the stock size on a 95 Tahoe should have the same size rims on yours think 16x7 I run 20's with different tires now
BirchyBoy
It depends on what you want the tire to do. I went with Michelin LTX M/S2 about a month ago because they are great riding, quiet and the price was too good to pass up. Every time I see a truck with Dynapro ATM's, I regret my decision because the Dynapro's are an awesome tire as well.
noJeepshere
Bountyfull, Utahrd
The stock size was a 245/75-16, but you can go to a 265/70-17 no problem. With a lift block in back and a torsion crank you can fit a 285/70-17 with minimal rubbing/trimming needed.
cent frum a smaert fone
Y2KpewterZ
I ran a 285/70-17 just fine with no rubbing or no crank.
Got some heated mirrors and window rain guards off a Denali that was being parted out. Also got a spare fog light switch I'll sell if any one is interested. I color matched the mirrors and guards ..
landsoul
  • Replaced the lower intake gasket
  • Replaced the Quick Connect
  • Replaced the thermostat
  • Flushed the coolant
  • Changed the oil
Tbruz
Windham NH
I added a Denali console to my 1997 2 door.
Picked one up and disassembled, stripped and repainted Med GM Gray.
reupholstered the wood grain bezel in dark charcoal leather to match the dash.
This one was complete right down to the key for the top arm rest console.
I also grabbed and installed the correct block off plate at the heater box to direct the air flow around this console.
Tbruz
95escahoe
Tbruz
Looks great
jerryjoe28
That Guy
cabot AR
Tbruz
looks good what all did you have to modify to get it in?
got the Hoe all aligned and ready to go today
[/URL][/IMG]
rolfsent
Cincinnati
Got my oil changed, replaced my 17 year old spare tire that had a screw in it and replaced the air filter.
Tbruz
Windham NH
jerryjo28,
No mods at all; its a direct drop in for the standard Tahoe/Yukon console.
Bolt holes aligned as well once I reversed the rear mounting bracket (from open side facing forward on the tahoe console to open side facing back for the denali console)
I replaced front block off plate at the blower diffuser(under dash) with the Denali specific one so that the air is directed around the new console rather than into it.
Rear controls are not operational but, not needed for me.
Still hoping that someone has the wiring info for the sub and amp(which I left installed).
Thanks
Tbruz
jerryjoe28
That Guy
cabot AR
jerryjo28,
Thanks
Tbruz
thanks alot man.... i am going to start keeping my eyes open for one after christmas. i love the look and the better cup holders
99YukonSLT
Ohio
Where'd you get your bumper from? I'm trying to find one that isn't chrome so I can get some fog lights on mine.
Tbruz
Windham NH
Originally Posted by Tbruz View Post
jerryjo28,
Thanks
Tbruz
Check the for sale section here, I just listed a second grey console I had.
Tbruz
qukon 95
Tbruz That sub is 1.4 ohms so you need to get a 1 ohm STABLE class d amp ( mono) my amp is a mtx 350 rms@1ohm there's no power rating for this sub so for me this 350w is powerful enough after I wired this sub up I took out my 2 12's ,2 500w kenwoods no more extra weight and nothing to see in back when parked.I
used the lp on amp I got it at 100hz.
Tbruz
Windham NH
qukon 95,
Do you know if there is any way to use it with the stock denali/esky amp and the non bose stock radio?
Thanks,
Tbruz
Hodmjstone
